Crank puller?
The main thing here is that:
Octalink and ISIS use the same crank puller.
X-Type normally does not require a crank puller, as it is "part" of the crank bolt assembly. You'll know if you have an X-Type crankset as the bearings for the bottom bracket will be external to the frame.
Square taper requires a unique crank puller.
