I have a 2005 Ford F150, 144'' wheelbase. (8 foot bed) The truck has a severe shake over a wide range of speed, between 35 and 70 mph. After ruling out the tires I discovered the two piece drive shaft has a center support with a rubber mount surrounding the bearing. The rubber has collapsed, allowing the shaft to move around. No problem I thought, just need to replace the center support.
Then things went bad. Very bad. The drive shaft in not serviceable, it must be replaced as a complete unit. The cost from a dealer is over $1,000. Yes one thousand dollars. I can get one built by a drive line shop for $700, shipped. I intend to call a local shop Monday morning and see what they can do.
Has anyone else been through this? Why would Ford build the truck so that the entire drive shaft has to be replaced, rather than the individual parts?
Does anyone have a recommendation? I live in middle TN, near Nashville.
Thanks,
Terry
Thanks,
Terry
