Originally Posted By: artificialist
Originally Posted By: mongo161
This is a Castrol ATF for Imports, (For Honda, Toyota, Nissan and other imports) along with Multi-vehicle use. This ATF is not the fluid for domestic vehicles.
Any comments or personal opinions and reviews would be welcome since I plan on using this fluid on some older Toyota vehicles. It is specs for Dexron III and Merc.
Thanks in advance.
I have used Castrol Import Multi Vehicle in Toyota T-IV, Nissan Matic J, and Honda Z1 applications without trouble.
Also, just because it says it is for import cars, that does not mean it will not work in certain American cars. It works where Dexron III and Mercon get used. Plus, some American cars get Japanese transmissions with different fluid needs.
I too am using the Castrol IMV ATF in 3 Asian vehicles with automatic trannys:
'01 Lexus RX-300 ~ 80K miles...Toyota T-IV
'04 Altima 2.5 S ~ 60K miles...Nissan Matic-D
'06 Mazda 3 2.0L ~ 90K miles...Mazda M-V
All 3 trannys act, "juuuuust" a bit differently than they did B/4 doing the D&F's...Not acting poorly(neither better nor worst), just differently! Shift points seem ODD! Especially on cold mornings. Then when they're all warmed up and have been driven for a few miles or so, all seems normal(can't define normal)...just what I was used to!
I can't say if it's the Castrol IMV or just the age of the trannys. All 3 trannys have been maintained very well with regular D&F's. I have written quick reviews on all 3 trannys as compared from how they were B/4 the IMV.
Now that I remember, I did buy 4qts of Castrol TransMax High Mileage ATF(I forgot about these 4 qts) for ~ $2.00-$2.50/qt from a PepBoys AutoParts Store discount table(6-8 months ago). They had a whole large table full of discontunued/closeout car products on this table that they(PB's) were getting off of their shelves. Lot's of car cleaning chem's and oils...20W50 etc. CHEAP!
