MolaKule
Staff member
Gasses drawn from the refinery towers are used to make PAO, a specific Gas-to-Liquid process.
The ethylene gas C2H4 or propylene (or other similar gases) are then "oligomerized" which means that the gas is transformed to various molecular weight liquids via polymerization, or the linking together of many single molecules. The products of these gases, via catalysts, results in a crystal clear liquid. [A catalyst is a chemical, usually a metal compound in this case, that increases the rate of reaction but itself does not undergo any permanent change].
The type of catalyst used determines the final molecular weight of the liquid. Low viscosity PAO's (2- 10 cSt) are made by using boron trifluoride catalysts, and heavy PAO's (40-100 cSt) are made using the alkylaluminum catalysts.
The liquid is then hydrogenated with hydrogen gas at approx. 250 C and 500 psi pressure with a nickel catalyst to further stabilize the fluid for oxidative and thermal stability.
Different catalysts, intermediate ditillation techniques, and different starting gases or combinations of gasses can be used to taylor- make PAO's for any viscosity or property required.
A gas chromatigraph will show the narrow molecular distribution of finished PAOs. This is in contrast to minerals oils and even VHVI oils, which show a wide distribution of molecules, i.e., both high and low molecular weight distributions.
A narrow disritbution of HC moleculaes means that the PAO fluid is stable in terms of
exhibiting low volatility and high VI. VI's of 150 are very common with PAO's. Of course, the higher the viscosity, the higher the Viscosity Index.
