Recently Amsoil Tested their 10w30 oil for the SL specification.
http://www.amsoil.com/performancetests/sequence_3f.htm
The Sequence IIIF test is a stringent API SL, ILSAC GF-3 test designed to measure oil thickening and piston deposits in high temperature service, as well as provide information on valve train wear. The test is designed to emulate high-speed service under high ambient conditions
quote:
Because AMSOIL is formulated to provide superior performance over extended drain intervals, testing was allowed to continue for 240 straight hours, three times the length of the standard Sequence IIIF test.
