Originally Posted By: 95busa
Dodge Magnum V8s come out of open loop at 178 degrees. The 180 is recommended by Hughes engines among others. It will be fine, and helps with pinging on Magnums without the so-called "death flash" that cut timing WAY back. Use it with autolite 3923s. Dyno proven all over dodgetalk.com, and I have run that combo on several 318 magnums and two 3.9 V6 magnums with no issues.
+1
I put a 180 on my truck several years ago, I have a 2001 Dakota with the 3.9 V6 Magnum engine. I also used 3923 plugs, and the reason I did it was to eliminate ping. The 180 and 3923's were the only solution that actually worked to get rid of the ping. It also helped improve power, at least on the butt-dyno. Some say the 180 and colder plug causes a loss of MPG but I never really noticed a difference. Maybe it dropped just a bit, not enough to worry about.
