I was told by the VW dealership, after $420, that my engine has high oil pressure. Engine starts, stalls and will not restart. Turns over like there is no compression. Dealership said lifters are overpressurized and keeping valves open. Once it starts it runs and starts great. Cleaned the oil filter housing and oil pump check valves but still have problem. Sometimes I can pump the throttle just right at startup and feather it to run
