Oil companies and the API always state that API specification levels are 'backwards compatable' - an oil that is certified SN wil work in all previous certification levels.
We know that the API has lowered the amount of Zinc and Phosphorus anti-wear additives in newer oils. Oil compnies and the API claim that newer anti-wear additives make up for the reduced Zn/Ph in newer oils.
So, if that is the case, WHY do some oil companies, many professional engine builders, and others push for, and assert, that older engines need high-Zn/Ph oils? The market for 'high zinc' oils keeps growing all the time, and there has been no real effort by the API to stop it, or get help stopping it.
If the API REALLY beleivs that lower-Zn/Ph oils will not harm older/high performance engines, why is there not more of an effort to make people see this?
OR...is the backwards compatability one big lie, and actually lower-Zn/Ph oils do NOT protectcertain engines, and all these builders and oil formulators are right, and there is a need for this oil?
Does the API TRULY believe what it is saying???
