Stock thermostat temp is 187 degrees.
I replaced the pump on a 5.3 with around 80,000 miles. I used an AC Delco from Rock Auto.
Internet research suggested that the pump to block gaskets are a common failure point on these. Mine was leaking from the weep hole, but the gaskets looked pretty crusty, too. "They say" the Fel-Pro gaskets are better than OEM. At any rate, the Fel-Pro has blue rubber compared to Chevy's orange.
