Originally Posted By: JHZR2
Do you use original Toyota keys? We see this in old MBs, which use steel keys, like Toyota does. If a cheap brass key is used, it will leave filings in the tumblers, and then failure will occur because all that junk gets stuck in there.
I've never seen a Toyota with a steel key.
