Hey guys,
I am experiencing an odd noise from my 2001 Honda CRVs engine. it appears to be coming from the crankshaft pulley. The pulley also wobbles quite a bit, it is actually digging into the timing belt cover. But here is what is causing me to think it is a problem in the bottom end and not the harmonic balancer: The noise and wobble are non existant until the engine begins to heat up, and is at its worst at full operating temp. I'm thinking changes in clearances due to higher temperatures cause the noise and wobble .
Here is a video.
You cant see the wobble in the video, but you can hear the hollow whine. Like I said the engine sounds normal until it approaches operating temperature.
140K miles on the motor, and it has never had any work done to it besides a timing belt at 110K and valves adjusted. I have had it since about 85K miles, nothing but Castrol GTX 5W30 every 3.5K-4K miles.religiously while its been in my hands. It burns about a half quart in between changes. It has never been run dry. (in my hands).
Since this is an oil forum, would a thicker oil possibly alleviate this problem for me to buy some more time with the engine until I can deal with it? And what are your thoughts on this being an internal problem vs an external problem? In my experience accessories dont discriminate between hot and cold if they are gonna make noise, and they would't cause the whole crankshaft pulley to wobble.
Here is a video.
