Diamond SP 111 v diaQueen Sp 111
They're just brand names. DiaQueen used to be Mitsubishi's OE fluid in Japan, and Diamond used to be their OE fluid in export markets. Not much of a difference now.
You're welcome!
You can use a multi-vehicle ATF meeting the SP-III requirement as well, if you have a hard time finding the stuff from Mitsu, or if it's ridiculously priced. Good luck!
kia and hyundai spIII are the same also if they are cheaper locally
I believe even the SuperTech "Multi-Vehicle Trans Fluid" meets this SPIII spec now.....
Don't quote me though....it could be notated on the Dexron IV bottle....it's on one of those 2
There is a retailer on eBay that sells DiaQueen by the gallon. It is current fill in all my Mitsubishis', minus the Evo
Thanks for all the input. So far the only ATF that I could find in Johannesburg to meet the SP 111 requirements is the DiaQueen from Mitsubishi. So guess I will just go with it. Even Hyundai dont have SP111 they use Transmax Z.
