I just picked up a Snapper 12 hp rider off of Craigslist.The PO had said the only problem he had w/the mower was with it choking down when he hit a thick patch of grass.
I brought it home changed the oil,plugs,air filter and old gas from it,sprayed the carb w/cleaner.It needs a battery but has a backup pull start.With the old gas it smoked and chugged(from the look of the old gas I drained he had filled it w/50-1 mix).With the new gas it runs pretty good.
Took it for a spin around the yard ,runs good.After about 10 minutes I hit a thick patch and the mower started to die .I released the blade pedal and engaged the clutch and the RPM's picked up .I reengaged the blade and the mower tried to die,had to disengage the blade.Moved the mower to a clear area.While doing this the mower dropped rpm and shut off a time or two.
Shut the mower off ,let it sit a few minutes.Cranked it up to move it to the shed .Same routine of bogging and engaging the clutch to keep the rpm's up.Probably had to do this 5-6 time.
I've never had a Snapper mower before,they have a good rep around here.Any ideas people?
