Chrome polish for spoke wheels
by gman2304
07/02/16 01:52 AM
'09 Nissan Sentra-Eni i-Sint XL 4AM 5w-30-10k.
by montero1
07/02/16 01:11 AM
Questions about manual transmission sounds
by Why_Anything
07/01/16 11:09 PM
HOW to learn PINSTRIPING & lettering ??
by SumpChump
07/01/16 11:08 PM
'96 Nissan Maxima - Intake R&R - EGR tube bent
by 92saturnsl2
07/01/16 11:00 PM
Anybody want a lot of 6 Carquest Blue 84060?
by CapitalTruck
07/01/16 10:38 PM
new Tundra color
by lawnman
07/01/16 10:36 PM
Bought A Yamaha XSR900 today!
by donnyj08
07/01/16 10:21 PM
Akebono ProACT vs EBC Ultimax "Blackstuff" pads
by slacktide_bitog
07/01/16 10:08 PM
Replace oxygen sensor by mileage ?
by Merkava_4
07/01/16 10:02 PM
I was slightly wrong on the Purolator transition
by slacktide_bitog
07/01/16 09:57 PM
Things your dogs have eaten.....
by OVERKILL
07/01/16 09:45 PM
Aidil, dandandan, dbertheau, Jennyp, dcdodge
58341 Registered Users
30 registered (bobt2382, Blkstanger, bdcardinal, chrisri, 3 invisible), 861 Guests and 17 Spiders online.
58341 Members
66 Forums
251131 Topics
Page 2 of 4 < 1 2 3 4 >
#2437707 - 11/17/11 08:07 PM Re: How to post used oil analysis results [Re: Quattro Pete]
Alamogunr Offline
Loc: Alamo, TN
Thanks. I really am dense.
#2444932 - 11/25/11 10:11 PM Re: How to post used oil analysis results [Re: wwillson]
SubLGT Offline
Loc: Idaho
Originally Posted By: wwillson
....................We prefer that you use a code block because the text remains aligned in the post the way it is typed. You can maintain a UOA history in a text editor .................... then simply paste the text into the code window. To post in a code window simply click on the # symbol.............
Tried the above, did not work for me. Had my (Macintosh) text document perfectly aligned with my headings and data, all in columns on left tabs. The tabs get lost/jumbled when the document is pasted into the code window. The data columns lose their alignment. shrug
#2536622 - 02/14/12 05:16 PM Re: How to post used oil analysis results [Re: wwillson]
teddyboy Offline
Loc: NC, United States
I am more dense. When I hit the # sign and select the code box, I get two boxes with the word code. Where I go from there, I haven't a clue. When I try to copy out of the Blackstone pdf, I am unable to highlight any of the text to copy. Any help would be greatly appreciated, but you need to realize that I have almost no skill here.
97 Camry M1 5W30 HM & OEM Filter
14 Camry TGMO 0W20 & OEM Filter
08 Volvo S60 M1 0w40 OEM Filter
#2536651 - 02/14/12 05:50 PM Re: How to post used oil analysis results [Re: teddyboy]
Quattro Pete Offline
Loc: Great Lakes
They you type everything you want to type between these two code tags. That's all there's to it.
There is no easy way to copy out of the Blackstone pdf. You need to type it all up by hand.
What was suggested previously was to copy text from another person's UOA that's already been posted here, like the one at the top of this thread. This will save you the effort of having to type all the element names from scratch. You will still need to replace the actual values though next to each element with your own from your own UOA report.
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#2536698 - 02/14/12 06:24 PM Re: How to post used oil analysis results [Re: Quattro Pete]
teddyboy Offline
Thanks for the reply; I still couldn't make it work so just did the best I could.
#2536708 - 02/14/12 06:31 PM Re: How to post used oil analysis results [Re: teddyboy]
Loc: Great Lakes
You mixed up the parenthesis.
#2536714 - 02/14/12 06:39 PM Re: How to post used oil analysis results [Re: Quattro Pete]
teddyboy Offline
I wish I knew what that means.
You must think I'm the dumbest person on the planet. Would it help to know that I have a Ph.D. in economics? Or would that just exacerbate your low opinion? In any event, I really do appreciate your trying. Maybe I'll be more patient when my students can't understand linear regression
#2537024 - 02/14/12 10:47 PM Re: How to post used oil analysis results [Re: wwillson]
teddyboy Offline
It's a miracle, I figured it out. The copied material goes between the two parentheses. Check out what I did in the test forum.
#2537230 - 02/15/12 08:19 AM Re: How to post used oil analysis results [Re: teddyboy]
Loc: Great Lakes
Yes. Sorry I wasn't clear on that. Glad you got it working.
#2537507 - 02/15/12 11:47 AM Re: How to post used oil analysis results [Re: Quattro Pete]
teddyboy Offline
No apology necessary; the problem was on the receiving end but I did eventually figure it out. Thanks again.
#2538384 - 02/16/12 08:26 AM Re: How to post used oil analysis results [Re: wwillson]
21Rouge Offline
Loc: Vinegar Hill
BITOG is the only forum I frequent which does not provide storage for uploaded files i.e. jpgs.
#2567211 - 03/14/12 11:00 AM Re: How to post used oil analysis results [Re: 21Rouge]
motor_oil_madman Offline
Loc: Houston, Texas
I'm pretty sure the guy wants info on his uoa and not a lecture on how to post it.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
#2568113 - 03/15/12 08:55 AM Re: How to post used oil analysis results [Re: motor_oil_madman]
21Rouge Offline
Loc: Vinegar Hill
The title of this thread being "How to post used oil analysis results".
#2659553 - 06/20/12 08:13 AM Re: How to post used oil analysis results [Re: 21Rouge]
Sam_Julier Offline
Loc: Connecticut
It would be extremely helpful to be able to upload the PDF of the Blackstone UOA. Could someone list the steps for this please? Thank you.
2007 Volvo V70 2.4L PC Duron 0W30
1993 Volvo 245 M1 HM 10W30
#2663261 - 06/24/12 01:06 AM Re: How to post used oil analysis results [Re: wwillson]
jkhawaii Offline
Loc: Oahu
posting the UOA using the method not recommended is the only way I know how.
Previous vehicle 2008 Pontiac G5 OLM and factory oil's mostly.
Currently 2013 GMC Terrain 2.4L FWD.
2012 Piaggio Fly 50 4T 4V. 2013 Honda PCX 150
