Originally Posted By: Zedhed
Originally Posted By: wolfc70
I did not like it in my FZ6. It worked great for 2000 miles, then shifting became very difficult when hot. Getting first gear became so bad that I had to come to a complete stop, shift to neutral, then go to first. I could not get first rolling up to a stop. Not impressed for $17 a quart. Repsol, Amsoil and Rotella T synthetic have all worked much, much better and retained excellent shift quality through out my 4000-6000 mile OCI's (usually the season).
What is this thing with shift quality? There are so many factors that affect shifting effort, how can anyone tell what the oil affects and all the other factors? Clutch play, oil temp, trans gear loading, engine speed? Why does everyone think that oil alone determines shifting quality?
Another urban motorcycle myth.....
Uh, my experience does not concur with the myth you state. Oil does make a difference, just the way different ATF can affect how a automatic shifts. Different oils stay in grade better than others, this affects shift quality and clutch operation. Some oils thicken, some oils thin, this all make noticeable changes in operation. It is not just in my head either. The FZ6 is known to have a somewhat recalcitrant gearbox. A good syn HDEO or other syn motorcycle oil makes it more livable. Go browse the FZ6 forums, the clunky, stubborn, notch gearbox is one of the bikes biggest gripes. RTS, Amsoil, and Mobil 1 seem to be the best cure.
