I'm looking for new tires for my A6 and since I have a speedometer that reads 1 mph fast at 65, I figured I'd move from the stock size of 235/45/17 down to 225/45/17 to correct the problem. My only concern is that the tires that I was considering in the original size are 94 load rating and in the 225 size are only 91 load ratings.
My question is, over the 4 tires the total load rating would go from 5908 lbs down to 5424 lbs on a car that weighs 4000. I am usually the only person in the car as we use our Mountaineer for family outings, so will the drop in load capacity make enough of a difference for me to worry about? There are other options in the 225 size that are XL rated at 94, but they are more expensive. If necessary, I will spend the money to make sure I have a tire that will carry the load properly. Thanks for the help.
