Here are the first 4 analysis for my 96 Land Cruiser. It has the gas 4.5L 1FEFZ motor. I'm the 3rd owner. The engine is stock except for an oil filter adapter I added. It lets me use a larger oil filter than the OEM Toyota filter.
Does this all look ok?
Took forever to type this in. Wish we could post links to a copy of the pdf file!
Cheers,
Scott
- Blackstone Labs
- About 70% short trips in city; 30% highway
- Oil & filter were changed at the same time
- filters were either WIX or equiv in Napa Gold
- 8 qt. capacity crank case
- 0 qts make up oil
The 92800 mile oil change/analysis I used Quaker State oil (kind of dumb in hindsight). I switched to Chevron Supreme for the 95300 oil change. Interesting to me is that it had the highest moly reading so far. The latest two changes I used Delo 400 10W-30. (I got the 10W-30 from a distributor).code:
Miles on oil 3,000 2,800 2,500 2,800
Total miles 101,000 98,100 95,300 92,800
sample date 7/26/06 3/30/06 12/12/05 7/30/05
Oil type Delo400 10w/30 Delo400 10w/30 ChevSupreme 10w/30 QState 10w30
Aluminum 2 1 1 1
Chromium 0 0 0 0
Iron 3 2 2 2
Copper 2 1 4 2
Lead 1 1 2 2
Tin 0 0 2 1
Moly 114 104 374 33
Nickle 0 0 0 0
Manganese 0 0 0 0
Silver 0 0 1 0
Titanium 0 0 0 0
Potassium 0 0 2 0
Boron 116 69 39 125
Silicon 9 7 16 9
Sodium 2 0 3 2
Calcium 3378 2394 1814 1777
Magnesium 8 7 8 7
Phosphorus 1251 969 666 517
Zinc 1381 1244 798 638
Barium 0 0 1 0
SUS Vis 64.5 63.5 56.4 57.3 (should be: 59-65)
Flashpoint 415 365 390 340 (should be: >375)
Fuel %
Antifreeze % 0 0 0 0 (should be: 0.0)
Water % 0 0 0 0 (should be:
Insolubles % 0.2 0.1 0.3 0.3 (should be: pre>
Cheers,
Scott
