Hi,
JAG - Whatever oil and maintenance programme you've been using the results look pretty fine to me!
Oil screen deposits are sometimes a mystery - the only serious lube related failure I've had was through a clogged screen and frozen drive oil pump shaft. This was an oil formulation matter!
I have seen many screens clogged with soft material - this was typically the result of poor service routines and a poor quality lubricant. Or a lubricant that did not meet the engine Manufacturers specification - and more diesel engine related (soot) than petrol engine
It is very hard to "blame" any specific lubricant when the engine has had a varied "diet". Cleaning an engine without dissassembly is at best a wish and mostly a wish that doesn't come true
