What should one look for when buying an OBDII scanner? Any makes/models to avoid? Or one I should look for? Or are they for the most part the same (VAG-COM for VWs excepted)?
Reason I ask is I see one on sale at Princess Auto for $34.99. It is a "MaxiScan MS300 CAN OBDII Code Reader". Will this do for very occassional DIY use? Vehicle it will be used on primarily is a 2006 Toyota Sienna.
