Check out the head off my extreme oil burner Honda
by Gasbuggy
02/08/16 01:31 AM
Unused Bosch 3313 cartridge
by Run
02/07/16 11:14 PM
David Fry in his own words
by Merkava_4
02/07/16 11:02 PM
Trans Pacific Partnership
by Merkava_4
02/07/16 09:57 PM
Schaeffer 711 10w30 Detroit 60 12.7
by TiredTrucker
02/07/16 09:17 PM
2012 Mazdaspeed3 transaxle 36k OCI 75W80
by MD1032
02/07/16 09:13 PM
Ford announces new assembly plant in Mexico.
by mrsilv04
02/07/16 09:10 PM
Guy with a cart full of Euro 5W40
by ledslinger
02/07/16 08:51 PM
Ever wonder how the new Camaro is made?
by BobsArmory
02/07/16 08:43 PM
Credit Card Reader 4 Smart Phone-Small Business
by crazyoildude
02/07/16 08:16 PM
talent doesn't pay like it used to.
by motor_oil_madman
02/07/16 07:46 PM
Disappointed with Accord after one Salt Exposure
by JHZR2
02/07/16 06:58 PM
slewman, lithium1189, Monktana, djh3, Compignite
56850 Registered Users
25 registered (citationxeleven, Axe Man, Black, chrisri, akela, A1O, 2 invisible), 476 Guests and 197 Spiders online.
56850 Members
66 Forums
244398 Topics
#2545666 - 02/23/12 12:44 AM Use for speed handles
JHZR2 Offline
Loc: New Jersey
Is there really a benefit/use for speed handles anymore?
I have one of these:
http://www.popularwoodworking.com/tools/tool-test-bosch-ps-10-2-i-driver
Bosch 12v li-ion driver. Can drive straight or head turned 90 degrees.
With an adapter to 3/8" square, I essentially have an electric ratchet that is shorter than a speed handle.
So is there a good reason to get/have one?
Thanks!
#2545739 - 02/23/12 07:23 AM Re: Use for speed handles [Re: JHZR2]
The_Eric Offline
Loc: Iowa
I think it boils down to preference. I prefer not to use one as I have plenty air ratchets and impacts.
2001 Hyundai Elantra 2.0
1998 Chevy Malibu 2.4
1995 Pontiac Grand Am 3.1
1979 Ford F-150 351M
#2545752 - 02/23/12 07:53 AM Re: Use for speed handles [Re: JHZR2]
VWguy Offline
Loc: Los Angeles, Ca
Maybe this is dating myself but back in the '70's and early '80's, Vasek Polak had his Porsche dealer in SoCal. It was, and still is, common practice to use a speed handle to R/R the oil strainer plate on any of the air-cooled cars but I remember seeing a guy using a 3/8 butterfly air tool during the installation of the 6mm nuts. Vasek was always in the shop and scolded the tech for this and instructed him to use a speed handle. This tech did it again and Vasek saw it and fired him on the spot!
If on a hoist, I still will use a speed handle for this.
#2545824 - 02/23/12 09:31 AM Re: Use for speed handles [Re: JHZR2]
440Magnum Offline
Loc: Texas
I rarely use a speed handle, but for the few jobs I use it on, I really like it. For example during engine assembly I always like to keep a manual feel on any bolts that are compressing a gasket rather than use an air or electric tool. So I pull out the speed handle for the repetitive task of running down valve cover bolts or oil pan bolts.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 Cherokee 4.0, '11 Grand Cherokee 3.6
#2545892 - 02/23/12 10:58 AM Re: Use for speed handles [Re: 440Magnum]
JHZR2 Offline
Loc: New Jersey
Well I use the electric and visually stop so that I can do the last few turns myself. Especially on something like a gasket where I want to do a fancy crisscross tightening to ensure it is even.
#2545997 - 02/23/12 01:07 PM Re: Use for speed handles [Re: JHZR2]
Stu_Rock Offline
Loc: Houston, TX
I don't even own a speed handle anymore. For long bolts, I use wimpy electric screwdriver or, for lug nuts, a cordless drill on a low clutch setting. I find it easier to align the power tool's axis with the fastener axis, which helps prevent galling when soft metals are involved. I'm too wobbly with speed handles.
#2546877 - 02/24/12 10:30 AM Re: Use for speed handles [Re: JHZR2]
Smoky14 Offline
Loc: Nowhere NM
Times may have changed, but the use of power drivers on aircraft hardware was forbidden, speed handle was your friend.
99 Acura 2.3CL 5speed MT
12 Ford Fusion 2.5S 6speed MT
05 Suzuki Bandit 1200.
#2549228 - 02/26/12 02:07 PM Re: Use for speed handles [Re: JHZR2]
67lemans Offline
Loc: wisconsin
we use them quite a bit in the aviation community hi-torque fasteners.
http://www.southeastbinders.com/
88 f150 4.9 valvoline 5w30
08 jeep patriot oreilly's syn 5w20
#2549494 - 02/26/12 06:43 PM Re: Use for speed handles [Re: JHZR2]
tom slick Offline
Loc: Central Coast, Calif.
Speed handles work great as screwdrivers because you can apply a lot of torque while applying pressure to the screw. Aircraft use a lot of screws.
The also work great when your batteries are dead (or non-existent) and by the time I drag a hose out and wait for the air compressor to pressurize I can usually have the fasteners out.
You get what you pay for...
So keep in mind how much you paid for this advice.
#2552263 - 02/29/12 11:21 AM Re: Use for speed handles [Re: JHZR2]
tig1 Offline
Loc: Illinois
Back in the day when I worked on jet engines I used one(3/8) all the time. Practical when you have many small bolts to tighten or loose.
2007 Ford Fusion 173,000 miles
M1 0-20 AFE
2007 Ford Focus 150,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
