my friends 96 accord ex has a problem with sinking brake pedal and it only happens once in a while. quite rarely that it happens and he has to add fluid every 6 months or so.
i inspected his lines and all were bone dry and the brake master cylinder was also dry, so no external leaks. i've never had experience with brake master cylinders. could it be leaking internally in the brake master cylinder?
also, when were braking, we can hear some dook dook dook noise from the front brakes.
also how can you rule out of its the brake master cylinder or the brake booster?
