Originally Posted By: sleddriver
Not sure if you're in a house, apartment, condo, etc. However, sealing up holes/cracks in exterior walls & around doors is time well spent. Look under sinks where the plumbing goes through the wall for cracks. I spent a lot of time on this last year in winter and the effect was noticeable. I had several open fir-down cavities in the attic that allowed cold air to sink in causing cold interior walls. I sealed these with 3/4" foamboard and caulk/foam. Also sealed ceiling light boxes, fans, can lights, plumbing & electrical holes through the top plates. Look on Fine Homebuildings website for info on this.
It is a 2 story house, with tile roof and a "vented" attic full of shredded newspaper. It is probably a trade off for cooler summer which goes up to 100 easily than for winter. Thanks for the advice, I'd probably give it a try when I get the chance, if nothing at least it should reduce mouse / squirrel dropping.
Originally Posted By: IndyIan
I assume you can close the chimney right now in your fireplace?
If not then I'd try plugging it as you might save alot of heat that way.
With only $88/month heating bills I can't see a wood burning appliance ever really paying off unless you can heat your whole house with it. Also even pellet stove only goes down to 10-12K btu which I suspect will creosote up the chimney if its always run that low.
I'd think a gas insert would be the cheapest to buy and probably to run as you'll never have to get the chimney cleaned as you won't have one.
Originally Posted By: meangreen01
I don't know how old your HVAC system is, but if it's old and nearing replacement you might want to consider a high efficiency heat pump. Your climate is ideally suited for it. Electricity rates will determine how much of a cost savings you'd see.
We already have natural gas furnace that is 4 burner (100k BTU I think), so natural gas insert will probably defeat the purpose of my intention.
HVAC heating is no go here because of the high electricity cost. One of my friend took the HVAC out to put in a natural gas furnace because he has been hitting the most expensive tier in electricity usage scale and natural gas, even factor in buying the 95% efficiency one, is a bargain in comparison.
My original thinking was to burn wood once in a while as I've seen everyone saying wood is cheaper. However I've seen insert costing $4k and wood costing $250 a cord now and it doesn't look like that big of a bargain, if anything anymore.
