Here's my second oil change on this unit. The IOLM was at 19% and I added 1.3 quarts at about 9000 miles.
Code:
Mileage 2285 10390
On Oil 2285 8105
Fe 26 23
Cr 0 0
Ni 0 1
Al 7 5
Cu 29 7
Pb 0 0
Sn 0 0
Cd 0 0
Ag 0 0
V 0 0
Si 39 21
Na 11 6
K 19 4
Ti 0 101
Mo 66 80
Sb 0 0
Mn 20 9
Li 0 0
B 139 82
Mg 9 14
Ca 1851 2402
Ba 1 0
P 669 745
Zn 708 810
Fuel dilut. 1.2
Soot
Water
Visc. 100C 7.6 7.5
Based on this, it looks like the oil is fine at 19% on the IOLM. In addition, it re-affirms the idea of doing the first change early. I noted that the Kendall has more additive at 8k than the factory fill did at 2200. Interesting since both are ConocoPhillips.
I will plan on running the next change out to 9,000 miles / 10% on the IOLM if the engine gets add oil. If I don't use a quart by 8,000 I'll change it then. The idea being that add oil replenishes the additives.
Code:
Mileage 2285 10390
On Oil 2285 8105
Fe 26 23
Cr 0 0
Ni 0 1
Al 7 5
Cu 29 7
Pb 0 0
Sn 0 0
Cd 0 0
Ag 0 0
V 0 0
Si 39 21
Na 11 6
K 19 4
Ti 0 101
Mo 66 80
Sb 0 0
Mn 20 9
Li 0 0
B 139 82
Mg 9 14
Ca 1851 2402
Ba 1 0
P 669 745
Zn 708 810
Fuel dilut. 1.2
Soot
Water
Visc. 100C 7.6 7.5
