How come discount tire doesn't use jack stands?
by motor_oil_madman
07/23/16 09:41 PM
SAFETY ?: ramps in rear and jack stands in front
by SavagePatch
07/23/16 09:03 PM
Pennzoil ultra 5w30 back in stock at Walmart.com
by kohnen
07/23/16 08:37 PM
Homelite weedeater not getting fuel
by Drew99GT
07/23/16 08:26 PM
Stability issue on 2015 F250
by Donald
07/23/16 07:25 PM
2016 Tacoma 3.5L V6 4x4
by NavyVet88
07/23/16 07:10 PM
Question on 05 Nissan tranny w/120k
by NattyBoh
07/23/16 06:58 PM
Denso FTF oil filters
by mclasser
07/23/16 06:50 PM
03 rav4 2.0 awd only took 2qts of mtf?
by Cxserver
07/23/16 06:49 PM
Who manufactures Subaru motor oil
by machfive916
07/23/16 06:26 PM
all Valvoline 5 qt jug sale at Meijer 7/24 to 7/30
by a1mfw
07/23/16 06:25 PM
ice cream
by Rick in PA
07/23/16 05:49 PM
SonofJoe, Axle_Needle, discobob, KHump, Zounds
58573 Registered Users
99 registered (02s4audi, 41 Plymouth, 4WD, 2015_PSD, 440Magnum, 123Saab, 13 invisible), 1588 Guests and 14 Spiders online.
58573 Members
66 Forums
252169 Topics
#2549373 - 02/26/12 04:51 PM Natural gas generator
Turbojoe Offline
Loc: Northern IL
I have a 17KW natural gas generator I have had for a number of years. I had always used 5-30 synthetic oil until last fall. I had most of a left over gallon of Rotella T6 and changed using the T6. I came accross some information about engine oil specifically for Natural Gas engines. I found two articles that caution against usind HDEO for a natural gas engines. http://www.cumminswestport.com/pdf/technical_bulletins/2009-05_Natural_Gas_Engine_Oil.pdf
http://www.machinerylubrication.com/Read/663/natural-gas-engine-lubrication
It concerned me a bit switched back to 5-30 synthetic PCMO. Just thought I would pass this along! Joe
2006 Jeep Liberty CRD, 2011 Buick Regal GS Turbo, Kubota G1800 diesel, Generac 17KW NG
#2549384 - 02/26/12 04:59 PM Re: Natural gas generator [Re: Turbojoe]
tig1 Offline
Loc: Illinois
A friend is a service tech on Generic stand by generators. He uses nothing but M1 5-30 per his tech school instructions. He has now serviced many of these units over the years with very good results. They are all either propane or natural gas.
Edited by tig1 (02/26/12 05:00 PM)
2007 Ford Fusion 184,000 miles
M1 0-20 AFE
2007 Ford Focus 156,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#2549385 - 02/26/12 05:00 PM Re: Natural gas generator [Re: Turbojoe]
widman Offline
Loc: Bolivia
You definitely do not want HDEO in Natural gas engines. Way too much sulfated ash that builds up on the valves, eventually channeling and causing wheezing and poor sealing.
Most are designed for about 0.5% ash content. There are many suppliers for it. There are exceptions to the right ash content, but most are .5
Richard's Car Restorations
#2549389 - 02/26/12 05:04 PM Re: Natural gas generator [Re: Turbojoe]
Turbojoe Offline
Loc: Northern IL
Yes, I know now. I tried to obtain NGEO from several sources with no success. They could only get 55 galllons. There are several good produts like Valvoline looks like it is availabe in gallons. Oh well, using the next best thing I guess.
Thanks!
Joe
#2549553 - 02/26/12 07:45 PM Re: Natural gas generator [Re: Turbojoe]
doitmyself Offline
Loc: MI
Turbojoe,
At my workplace we have a 17kw Kohler generator with a 35hp Ford engine in it running on NG. When I asked the Ford tech. people in Dearborn about the need for special oil 10 years ago they said I would be fine on regular automotive oil.
If you read your links, the Noria one talks about engines needing some ash to protect the valves. It also states that many NG engines run on low OR medium ash oils. Both of your links seem to relate to very heavy duty, large industrial engines (the Cummins links to a very specific engine).
All I'm saying is that it might be good to investigate further before taking the info in your two links and applying to all natural gas engines.
Regarding HDEO, Rotella T5 is 1% ash.
If you learn more, please share, as I am interested too.
"There are things you do that put food on the table, and there are things you do that feed your soul." I am blessed to have them be the same things.
#2549587 - 02/26/12 08:19 PM Re: Natural gas generator [Re: Turbojoe]
Turbojoe Offline
Loc: Northern IL
Thanks doitmyself,
I am not at all concerned with running PCMO in my gennie. I will just use the same oil I put in the wife's car. The ash content is .5-.6 % ash. I wanted to get the T6 out before it had a long run. I do realize the engines in the links I posted were in a different than my little twin cylinder! I use the T6 in my Jeep CRD so it was just some that was left over.
Take care!
Joe
#2549611 - 02/26/12 08:42 PM Re: Natural gas generator [Re: Turbojoe]
RF Overlord Offline
Loc: Cape Cod, MA
Interesting. At work we have a 250kW natural gas standby set with a big 6-cylinder Cummins and the factory manual says Valvoline Premium Blue 15W-40 HDEO is the preferred oil.
Supercharged '03 Mercury Marauder - Trilogy Motorsports #61
PP 5W-30 / MC FL820S
Y2K Grand Marquis GS - daily driver
QSUD 5W-20 / MC FL820S
#2549616 - 02/26/12 08:45 PM Re: Natural gas generator [Re: Turbojoe]
doitmyself Offline
Loc: MI
Oh. I thought maybe you had something like this: crackmeup
What oil are you using with 0.6% ash?
#2549651 - 02/26/12 09:09 PM Re: Natural gas generator [Re: doitmyself]
Turbojoe Offline
Loc: Northern IL
doitmyself,
All the furnaces in my subdivision would go out when that kitty Cat started up!
I am using QSUD 5w30 now. I used M1 5W30 before.
Joe
