car is 2001 acura integra.
recently replaced with:
exedy clutch master cylinder
exedy clutch slave cylinder
russell stainless steel clutch line
honda oem hose connecting reservoir to clutch master cylinder
supertech blue bottle brake fluid
car runs fantastic, but im having a problem with dirty clutch fluid. my reservoir is black again after about 2k miles of bleeding the lines. Anyone know what is causing the fluid go to black? What other component can be causing this? I had this problem before i replaced all these things. i thought the problem would be fixed after replacing the clutch master and slave cylinder since they were slightly leaking.
looks like this:
looks like this:
