My goal with extended OCIs is to minimize the waste of my time and our natural resources. But we don't want wear out our vehicles prematurely.
LAB: OIL ANALYZERS(Indy)
The first #s are from Dec.2010. The oil had 8.1k miles and 8 mths.
The second #s are from May 2011. The oil had 14.3k miles and 13 mths.
The third #s are from Feb 2012. The oil had 12.3k miles and 9 mths.
I installed a TopDog engine oil bypass filter system w/EaBP90 bypass filter in Jan. of 2011. At the same time, I modified the FF oil filter adapter to accept a larger diameter filter. I've had an Amsoil Ea011 in the FF position since the last change. Oil capacity is 6 qts.
The car had 68,300 miles at the 3rd sample. There wasn't any makeup oil added. It doesn't use any oil. The air filter element has been in place for 14 mths and there aren't any leaks in the induction system that I can find?. The car doesn't use any anti-freeze(DexCool).
Lab Comments: Lubricant and filter change is suggested if not done at sampling time; Total Base Number is SEVERELY LOW; Infrared results indicate OXIDATION is SEVERELY HIGH; Infrared results indicate that NITRATION is at a MINOR LEVEL; SILICON is high, however, there does not appear to be any wear as a result; SILICON sources can be abrasives (dirt, Alumina Silica), seals and gasket material, lube additive or lube supplement, and/or environmental contaminant; FUEL DILUTION is at a MINOR LEVEL.
Code:
WEAR METALS-PPM
Iron 20....42....25
Chromium 0......0....0
Copper 7......7....5
Tin 0......0....0
Lead 0......0....0
Chrom 0......0....0
Nickel 0......0....0
Alum 5......6....5
Silver 0......0....0
Cadmium 0......0....0
Vanadium 0......0....0
CONTAMINANT METALS-PPM
Silicon 42.....50....64
Sodium 15.....27....22
Potassium 4......3.....4
MULTI SOURCE METALS
Manganese 3......3....1
Titan 0......0....0
Molybdenum 10.....8....4
Antim 0......0....0
Lithium 0......0....0
Boron 9......7....7
ADDITIVE METALS-PPM
Magnesium 12......12....13
Calcium 3115..2949..3269
Barium 0......0.....0
Phosph 542...554...588
Zinc 627...642...613
V100C 10.1...10.4...10.1
I-R Oxidation 44......63.....72
I-R Nitra 35......42.....47
TBN 8.01...1.72...1.67
Fuel
Soot Vol
I'm ok with the results except for the fuel dilution? This is the wifes car and she does alot of short trips. Maybe taking a sample in the winter time needs to be done after a long trip, and not after a bunch of short ones? Do you think I need to clean the MAF sensor? It's never been cleaned.
What do ya think please???
I changed the oil with Amsoil again, and I changed the FF filter to a Fram XG2 this time. I drained the old oil out of the bypass filter, refilled it w/new oil, then reinstalled it full of new oil. I'm thinkin about doing the next analysis at 11k miles?
Code:
WEAR METALS-PPM
Iron 20....42....25
Tin 0......0....0
Lead 0......0....0
Chrom 0......0....0
Alum 5......6....5
MULTI SOURCE METALS
Titan 0......0....0
Antim 0......0....0
Boron 9......7....7
ADDITIVE METALS-PPM
Fuel
Soot Vol
