Many intakes only replace the first half of the piping or less. That allows them to adapt a conical filter, but there is still restriction left from the OE pieces in many cases.
I would recommend a cheap intake that comes with a good heat shield, and then get some universal silicone hose/tubing that is pre-bent where needed, and silicone.couplers, and replace the rest of the OE tubing up to the throttle body with that. It can be done for $40 if you go with good quality, 4ply silicone piping.
Then wrap all of it in insulating wrap, the exhaust wrap works fine if you then cover it with reflective aluminum tape.
The difference was significant in my case, as 90degree bends were smoothed out to 45 degree ones, and it is quite clear visually that it is a much smoother path. I also used a quality temp resistant coating on the entirety of it, and the heat shield too.
It dropped intake air temp significantly, with the air being barely above ambient. Just the tubing proved to provide an additional 3rwhp on a naturally aspirated car, with double that after everything was isolated from engine bay heat. Of course, now it is hard to tell because the major heat makers in my engine no longer put out that kind of heat (ceramic headers, intake manifold, valves, etc all Swaintech coated and cats removed), so underhood temps are very low.
On a turbo car, I would consider getting one of those turbo covers that prevents heat from transferring to or from the rest of the engine bay. I do not know much about that, but I know people who have had their entire turbos Swaintech coated and with very good results.
