2000 GMC Safari All-wheel drive with 164,000. Dropped pan, changed filter, added 4qts, then took off return line to transmission and flushed remaining fluid out. Took another 8qts to get clean cherry red fluid. Used NAPA Dex III.
1991 Nissan Sentra 1.6L, 217,000mi, atf drain/refill every 15k miles. Every time I pull the dipstick to check the level, theres some black crud and when I would do drain/refills, the fluid would look red-brownish. Time to do a pan drop.
First pan drop in it's life, cleaned tons off crud of the magnets, installed a new filter, pan gasket, refilled with Dexron VI.
Originally Posted By: ltslimjim
Last month with clutch replacement(note sig):
OUT: Amsoil MTF 5w-30 Synchromesh
IN: Honda Genuine Type-II MTF(5w-20?)
Def likin' the Amsoil a little better at this point. Waiting till clutch is broken in, by the spring will switch back to Amsoil.
I assume you had the dealer replace the clutch with it having Honda Genuine Type-II MTF in it now over the Amsoil. Did you tell them that you would see them in another 250,000?
Lol, nah it was a local shop I use now. It was either Honda Genuine Type-II MTF or motor oil. I forgot to order more Amsoil MTF ahead of time, so chose the Honda Genuine. Not a bad product or anything, just prefer the Amsoil now is all.
Dealer probably would've been much more expensive. For this job I paid about $565 total parts/labor(I purchased my own clutch kit).
1996 Chevy Astro 4L60E - dropped pan, replaced filter, refilled approx 5 quarts of Supertech Dex III, pulled cooler line and flushed approx 8 quarts of fluid through, total amount of fluid used between refill and flush was 14-15 quarts. Old fluid was 10 years old, 50k miles. Pan was very clean. Not much material in there. I also replaced the rear end fluid with 75W90 at the same time. 105k on the van at this service.
07 Mark LT Dropped pan and cleaned, new filter. Added 5 qts of Mercon 5. Drove to Ford and had whole system exchanged. Added 13 oz of redline red. Good to go!
21 January 2012, DIY
Total km 113,382, ATF km ca. 23,500
2004 Camry, U241E transmission
Drained 3.6 L of mix 60-40 of Toyota T-IV and Amsoil ATF
In went 3.6 L of Toyota T-IV
2005 Chevy Colorado w/104K Changed yesterday MTF Fluid to Redline MT 90. Shifts great today, though hearing a little whine in 5th at 65 mph. Had 10w40 ST motor oil in for 800 miles prior and it shifted fine too. Used that as a quik flush. Previously had Pennzoil Syncromesh in for approx. 40K miles. and that shifted great too.
