My 2000 Toyota Echo with 110K miles (originated from Canada) has rusty hole on its exhaust pipe right in front of the muffler which makes some loud noise. I did some research on the Internet on fixing the hole and found the true solution is to replace the pipe instead of patching it up.
I want to have some ideas on how the replacement work with few questions:
1) Should the whole pipe from the exhaust manifold to the muffler be replaced as a unit? If so, does this include the catalytic converter even it is still good?
2) Can just the section of pipe between the catalytic converter and the muffler be replaced?
3) Should the muffler be replaced along with the pipe?
4) I called a local Shell gas station that has a garage. They said the work must be done by a muffler shop. Does anyone know a good shop in the Rockville area of Maryland? I have heard lots of bad things on the muffler chains like Midas.
Thanks,
Simon
Thanks,
Simon
