my work vehicle is a 2007 suburban 2500 3/4 ton w/350? 79,000 miles and 20 hour a day running. now shows temp gauge totally cold as in not working - usually shows lower 1/4 as somewhat cold, now totally cold and message panel says engine hot, shutting off a/c, run idle only, or words to that effect. I'm guessing this is limp home mode. This happens even when just started after cold, never appears to be overheating. What is cause and solution? Temp sender? is that an easy quick replace? would t/stat link to this? thoughts? comments? probably same setup as pick up 3/4 ton.Thanks.
