Question about grease for exmark mower
by Jetstreamz06
13 minutes 30 seconds ago
Grease on door seals and glass
by JHZR2
28 minutes 14 seconds ago
15k miles on Fram xg6607 2011 Mazda 2
by micmac
47 minutes 12 seconds ago
2001 Mazda Tribute atf
by urrlord
57 minutes 18 seconds ago
Bought a 21..95 Lawnmower battery at O'Reiily's
by andyd
Today at 09:20 PM
How do you feel about castrol edge 0w30 for a z06
by Jetstreamz06
Today at 08:33 PM
04 Mercedes c230 any good
by barkingspider
Today at 08:29 PM
Best spark plugs?
by jk_636
Today at 08:13 PM
Recoil, .380 versus .32?
by bobbob
Today at 07:47 PM
Winter + Slightly off concentration of glycol
by nobb
Today at 07:31 PM
Good synthetic oil for ford transit ecoboost?
by Jetstreamz06
Today at 07:26 PM
Reuse fram XG for 1 more O/C?
by gabriel9766
Today at 07:21 PM
stydel311, jackadf, rlb4, apenland01, 2ManyMiles
57767 Registered Users
84 registered (2015_PSD, 74DartSport, 06AllAmerican, 2KBMW, B320i, 10 invisible), 1315 Guests and 318 Spiders online.
57767 Members
66 Forums
248335 Topics
Page 2 of 4 < 1 2 3 4 >
#2437707 - 11/17/11 08:07 PM Re: How to post used oil analysis results [Re: Quattro Pete]
Alamogunr Offline
Loc: Alamo, TN
Thanks. I really am dense.
#2444932 - 11/25/11 10:11 PM Re: How to post used oil analysis results [Re: wwillson]
SubLGT Offline
Loc: Idaho
Originally Posted By: wwillson
....................We prefer that you use a code block because the text remains aligned in the post the way it is typed. You can maintain a UOA history in a text editor .................... then simply paste the text into the code window. To post in a code window simply click on the # symbol.............
Tried the above, did not work for me. Had my (Macintosh) text document perfectly aligned with my headings and data, all in columns on left tabs. The tabs get lost/jumbled when the document is pasted into the code window. The data columns lose their alignment. shrug
#2536622 - 02/14/12 05:16 PM Re: How to post used oil analysis results [Re: wwillson]
teddyboy Offline
Loc: NC, United States
I am more dense. When I hit the # sign and select the code box, I get two boxes with the word code. Where I go from there, I haven't a clue. When I try to copy out of the Blackstone pdf, I am unable to highlight any of the text to copy. Any help would be greatly appreciated, but you need to realize that I have almost no skill here.
97 Camry M1 5W30 HM & OEM Filter
14 Camry TGMO 0W20 & OEM Filter
08 Volvo S60 M1 0w40 OEM Filter
#2536651 - 02/14/12 05:50 PM Re: How to post used oil analysis results [Re: teddyboy]
Quattro Pete Offline
Loc: Great Lakes
They you type everything you want to type between these two code tags. That's all there's to it.
There is no easy way to copy out of the Blackstone pdf. You need to type it all up by hand.
What was suggested previously was to copy text from another person's UOA that's already been posted here, like the one at the top of this thread. This will save you the effort of having to type all the element names from scratch. You will still need to replace the actual values though next to each element with your own from your own UOA report.
'02 530i (PPE 5W-40)
'15 Q5 3.0T (Edge 5W-40)
#2536698 - 02/14/12 06:24 PM Re: How to post used oil analysis results [Re: Quattro Pete]
teddyboy Offline
Thanks for the reply; I still couldn't make it work so just did the best I could.
#2536708 - 02/14/12 06:31 PM Re: How to post used oil analysis results [Re: teddyboy]
Loc: Great Lakes
You mixed up the parenthesis.
#2536714 - 02/14/12 06:39 PM Re: How to post used oil analysis results [Re: Quattro Pete]
teddyboy Offline
I wish I knew what that means.
You must think I'm the dumbest person on the planet. Would it help to know that I have a Ph.D. in economics? Or would that just exacerbate your low opinion? In any event, I really do appreciate your trying. Maybe I'll be more patient when my students can't understand linear regression
#2537024 - 02/14/12 10:47 PM Re: How to post used oil analysis results [Re: wwillson]
teddyboy Offline
It's a miracle, I figured it out. The copied material goes between the two parentheses. Check out what I did in the test forum.
#2537230 - 02/15/12 08:19 AM Re: How to post used oil analysis results [Re: teddyboy]
Loc: Great Lakes
Yes. Sorry I wasn't clear on that. Glad you got it working.
#2537507 - 02/15/12 11:47 AM Re: How to post used oil analysis results [Re: Quattro Pete]
teddyboy Offline
No apology necessary; the problem was on the receiving end but I did eventually figure it out. Thanks again.
#2538384 - 02/16/12 08:26 AM Re: How to post used oil analysis results [Re: wwillson]
21Rouge Offline
Loc: Vinegar Hill
BITOG is the only forum I frequent which does not provide storage for uploaded files i.e. jpgs.
#2567211 - 03/14/12 11:00 AM Re: How to post used oil analysis results [Re: 21Rouge]
motor_oil_madman Offline
Loc: Houston, Texas
I'm pretty sure the guy wants info on his uoa and not a lecture on how to post it.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
#2568113 - 03/15/12 08:55 AM Re: How to post used oil analysis results [Re: motor_oil_madman]
21Rouge Offline
Loc: Vinegar Hill
The title of this thread being "How to post used oil analysis results".
#2659553 - 06/20/12 08:13 AM Re: How to post used oil analysis results [Re: 21Rouge]
Sam_Julier Offline
Loc: Connecticut
It would be extremely helpful to be able to upload the PDF of the Blackstone UOA. Could someone list the steps for this please? Thank you.
2007 Volvo V70 2.4L PC Duron 0W30
1993 Volvo 245 M1 HM 10W30
#2663261 - 06/24/12 01:06 AM Re: How to post used oil analysis results [Re: wwillson]
jkhawaii Offline
Loc: Oahu
posting the UOA using the method not recommended is the only way I know how.
Previous vehicle 2008 Pontiac G5 OLM and factory oil's mostly.
Currently 2013 GMC Terrain 2.4L FWD.
2012 Piaggio Fly 50 4T 4V. 2013 Honda PCX 150
