This analysis was performed by blackstone on 4/13/06
EQUIPMENT MAKE: 2004 Mercedes Benz E500
EQUIPMENT MODEL: 5.0L V-8
FUEL TYPE: Gasoline (Unleaded)
Miles on Engine: 31,200
OIL USE INTERVAL: 10,005 Miles
OIL TYPE & GRADE: Mobil 1 0W/40 (Gas)
MAKE-UP OIL ADDED: 0 qts
The answer to your question is, we don't think these were too many miles to run on the oil and you could go longer if you wanted. Universal averages show typical wear metals from the Mercedes Benz 5.0L V-8 after about 4,600 miles run on the oil. All your wear read well within the average range and this is especially good since this oil was run a lot longer than average. Silicon is a little high at 12 ppm and may show the need for fresh air filtration. The TBN was 4.4, still plenty high. 1.0 is low. Add another 4,000 and check back.
MI/HR ON OIL 10,005
MI/HR ON UNIT 31,200
The results are on the left and averages on the right
ALUMINUM 3 3
CHROMIUM 1 1
IRON 10 7
COPPER 9 7
LEAD 2 4
TIN 1 2
MOLYBDENUM 77 37
NICKEL 0 0
MANGANESE 1 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 0 1
BORON 83 69
SILICON 12 9
SODIUM 11 16
CALCIUM 2102 1977
MAGNESIUM 186 214
PHOSPHORUS 905 911
ZINC 1040 1052
BARIUM 0 0
Properties Test Value | Should be
"SUSVISCOSITY @ 210 ºF" 65-78 | 67.2
"FLASHPOINT IN ºF" >375 | 460
"FUEL %" "ANTIFREEZE %" 0 | 0
"WATER %" "INSOLUBLES %"
I will be posting my analysis for my Lifettime ATF soon too.
MI/HR ON OIL 10,005
ALUMINUM 3 3
CHROMIUM 1 1
IRON 10 7
COPPER 9 7
LEAD 2 4
TIN 1 2
MOLYBDENUM 77 37
NICKEL 0 0
MANGANESE 1 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 0 1
BORON 83 69
SILICON 12 9
SODIUM 11 16
CALCIUM 2102 1977
MAGNESIUM 186 214
PHOSPHORUS 905 911
ZINC 1040 1052
BARIUM 0 0
