I am planning on changing the transmission fluid in our 2002 Malibu this spring. It has the 4T40E transmission. The car currently has about 110k miles on it. The fluid/filter has never been changed but I believe some of the fluid was exchanged at some point in the past (but am not confident one way or another).
The car is driven very easily (and has been since new) with mostly highway, low load driving.
I am planning on draining and filling with Castrol Dex VI fluid.
Is there anything I should be concerned with? Filter brands that stand out? Gasket brands? RTV on the pan bolts? Ordinarily I would not wait this long to drain the fluid but I haven't really had a big hand in maintenance on this car. The fluid is still bright red and smells like new fluid, for what that's worth. Admittedly I don't have much experience with automatic transmissions.
Thanks in advance.
Thanks in advance.
