Hate those adds that start with, "Lean 1 weird ...
by OneEyeJack
04/30/16 05:11 AM
How Much Olive Oil Do You Use?
by GrtArtiste
04/30/16 03:20 AM
Hyundai filter 26300-35503 10PK for 35.40 FREE S&H
by GumbyJarvis
04/30/16 01:10 AM
Dope smoking genius Laremy Tunsil NFL Draft Pick!
by GiveMeAVowel
04/29/16 09:50 PM
'13 Honda VFR1200 Motul 10w-50, 5,300 miles.
by montero1
04/29/16 09:35 PM
Anyone Using Spline Sockets?
by JHZR2
04/29/16 09:33 PM
Anyone Tryed Spectra Premium O2 Sensors?
by Mr_Accord
04/29/16 09:16 PM
UPS package tracking is so confusing!
by Klutch9
04/29/16 07:52 PM
Dupont non-stick lube
by buck91
04/29/16 07:47 PM
House electrical wiring question
by road_rascal
04/29/16 07:46 PM
Air pressure question
by aquariuscsm
04/29/16 07:43 PM
Fllow the DOT's
by WyrTwister
04/29/16 07:23 PM
hdwizard21, raihan, aceracres, kg4geq, red_bulldog
57748 Registered Users
36 registered (06AllAmerican, 2002 Maxima SE, Al, Abakev, AEHaas, 1foxracing, 3 invisible), 709 Guests and 295 Spiders online.
57748 Members
66 Forums
248234 Topics
Page 1 of 3 1 2 3 >
#2528723 - 02/07/12 07:19 PM Recommendation: Front Pads for 2008 BMW 528xi
barlowc Offline
Loc: Southeast Michigan
My brother e-mailed me today. His 2008 BMW 528xi has 69K miles on it and I guess there's some kind of indicator saying that he'll need new pads in approximately 1K miles.
I've done pads and rotors on three cars before. A 98 Grand Prix, a 99 Grand Prix, and an 02 Civic. The instructions/procedure for doing the BMW look pretty much the same.
Anyone have a 5-Series and have a pad recommendation? I took a peek at AAP's site and saw Akebono, Wearver, and Beck/Arnley as options.
When replacing the pads, I should really get the rotors turned, right? (That's assuming there's still enough thickness to be turned.)
If they need to be replaced, AAP listed Akebono, Wearver, and Beck/Arnley as options just like the pads.
Thoughts and input appreciated, as always. cheers
2013 BMW 335i xDrive Sport Line (26K Miles)
#2528752 - 02/07/12 07:37 PM Re: Recommendation: Front Pads for 2008 BMW 528xi [Re: barlowc]
Chris Meutsch Offline
Loc: Cincinnati
The Centric's on Rock Auto are a "favorite." My mechanic likes ATE on foreign cars. Both are available, at a significant price difference.
"I bow to the master troll engineer20."
---cptbarkey, 3/21/16
#2528769 - 02/07/12 07:49 PM Re: Recommendation: Front Pads for 2008 BMW 528xi [Re: barlowc]
Quattro Pete Offline
Loc: Great Lakes
BMW's stance on the subject is that they don't recommend turning the rotors. They recommend replacing both pads and rotors at the same time. The old rotors will typically not make it through a second set of pads and you don't want to be putting on new rotors on old pads.
As far as brands, I'd actually recommend sticking with OEM. I've tried aftermarket pads such as Akebono which although helped reduce brake dust, were not as good performance-wise as OEM.
By the way, you will also need to purchase a wear sensor. I don't think one comes with the pads.
'02 530i (PPE 5W-40)
'15 Q5 3.0T (Edge 5W-40)
#2528806 - 02/07/12 08:16 PM Re: Recommendation: Front Pads for 2008 BMW 528xi [Re: barlowc]
dparm Offline
Loc: Chicago, IL
Audi brake pads have the sensors built-in, if you stick with OEM.
2011 BMW M3 sedan ZCP
#2528820 - 02/07/12 08:25 PM Re: Recommendation: Front Pads for 2008 BMW 528xi [Re: barlowc]
Jim 5 Offline
Loc: Calgary Canada
The best pads I have found for BMWs for least dust and closest to OEM performance is AXXIS/PBR Deluxe Plus.
Jim A
07.5 GMC Sierra 2500HD LMM Rotella 15w-40
09 Odyssey EX-L CT 5w-20
66 Bronco QS 10w-30
08 BMW K1200S Rt 15w-40
08 Pitster Pro X4 Rt 15w-40
#2528827 - 02/07/12 08:31 PM Re: Recommendation: Front Pads for 2008 BMW 528xi [Re: barlowc]
EricF Offline
Loc: SF Bay Area
ATE and Akebono are very good for BMW's..
1993 Ford Ranger XLT 4.0L 4x4 (240k) 5W-30 Synpower
2006 Saturn Relay-3 3.5L (85k) 5W-30 Synpower
2012 Ford Fusion SE 2.5L (39k) 5W20 M/C Semi Syn
#2528833 - 02/07/12 08:39 PM Re: Recommendation: Front Pads for 2008 BMW 528xi [Re: barlowc]
Audios Offline
Loc: Lyndhurst NJ
Dont turn the rotors, measure them with a dial caliper to see if theyre still within spec, which should be stamped on the hat of the rotor. I think its 27.6mm but its been a while. As far as pads, Id go with Akebonos. Ive had good results with them so far on my S4, as well as other customers BMWs. Otherwise ATE, Textar or Pagid are OE.
I cant stress enough to try and avoid cheaper pads. BMW stresses their brake pads much differently than many manufacturers and can lead to chipping, cracking or fracturing of the pad. The DSC system in the car "preps"the pads if it senses you lift the pedal suddenly by bringing the pads within 1mm of the rotor face and priming the abs pump. If in the rain, depending on what wiper speed, it will bring the pads into contact with the rotors very slightly, wiping the face of the rotors and drying the pads. It can heat the pads to cooking hot in an effort to keep them dry in a heavy downpour if it has to. It uses the brake wear sensor to measure the pad life/depth, so its important to replace the sensor everytime.
Edited by Audios (02/07/12 08:40 PM)
1997 Audi A4 1.8t-LM 5/40 Synthoil Premium
2002 VW Golf TDi-Mobil 1 5/40 ESP
#2528851 - 02/07/12 09:01 PM Re: Recommendation: Front Pads for 2008 BMW 528xi [Re: barlowc]
JHZR2 Offline
Loc: New Jersey
textar yellow box.
#2528856 - 02/07/12 09:08 PM Re: Recommendation: Front Pads for 2008 BMW 528xi [Re: barlowc]
nleksan Offline
Loc: Cincinnati, OH
Stoptech ST are inexpensive and outperform every other street pad I have used, including Axxis Dlx/Ult, Hawk HPS, EBC (all), Akebono Euro Metallic/Semi-Met, Cool Carbon, OEM, and about a half dozen others.
Very good stopping power, long life, very low dust, strong initial bite even in subzero temps, no noticeable performance degredation in wet (tires lost traction before brakes lost clamping power, and that is with Michelin PS2s/Pilot Super Sports and Pirelli P-Zero Nero/Corsa System tires), and when bedding them initially they only lost about 10% of their power after 13th consecutive 70mph-5mph full-powered stop (it was literally accelerate to 70mph in 6-7sec then immediately slam on brakes then fully accelerate, and so on... I had smoke coming from wheel wells before I noticed a loss of grip).
I use them on my 325i daily driver with Stoptech slotted rotors, Stoptech SS lines, and Motul RBF600 fluid as well as on my 328 with its 6piston 14.8" 2pc slotted floating rotors front / 4piston 14.25" (same 2pc slotted) rotors rear Big Brake Kit with ST SS lines and RBF600 (for the street, different pads for track). I have not yet had to replace any of them, with over 60k hard miles combined.
Seriously, for the price, they are fantastic. I don't know that I will ever buy anything else, and I used Axxis Ultimates for a long time but these have them beat in every way.
00 328Ci(419rwhp/392rwtq) RL/Motul/OS Giken
06 M3 ZCP/6MT - RL
01 325i - RL/RP
03 M5 - RL
88 M6 (Eu) - RL
95 M5 (Eu) - RL
#2528898 - 02/07/12 09:49 PM Re: Recommendation: Front Pads for 2008 BMW 528xi [Re: nleksan]
barlowc Offline
Thanks for the input thus far!
Would Wearever rotors from AAP be a bad choice?
Right now I can get them for $56 each (they're usually $108) minus 15% and I'll get a $50 off coupon good on purchases of $100 or more. I could then use that coupon towards a set of Akebono Ultra Premium Ceramic "Euro" pads which run $111.
Total cost for new front rotors and pads would be about $170.
#2529272 - 02/08/12 09:05 AM Re: Recommendation: Front Pads for 2008 BMW 528xi [Re: barlowc]
dparm Offline
Loc: Chicago, IL
I would avoid those generic rotors. The cooling veins are always spaced wrong and are often too thick.
#2529327 - 02/08/12 10:07 AM Re: Recommendation: Front Pads for 2008 BMW 528xi [Re: barlowc]
nleksan Offline
Loc: Cincinnati, OH
I agree with dparm 100%
This is a >$50k, 4500lb+ sport sedan. Do not buy any brake parts because they are inexpensive. DO buy the best performing parts you can get.
The Stoptech pads I mentioned should be around $75 per axle, and some decent E-Coated Centric Slotted rotors around $175 per axle.
It is not cheap, but it is not like dropping $6k on a front and rear Big Brake Kit. The price to performance ratio is, however, probably the best you will find.
Also, I recommend going with slotted (never drilled) rotors because the Stoptech pads are designed to work with them so there is little or no loss in pad life, they have more consistent braking, they work very well in the wet, and the newer ones have slots that do not extend fully to the inside or outside edge of the disc so there is no loss of structural integrity.
06 M3 ZCP/6MT - RL
01 325i - RL/RP
03 M5 - RL
88 M6 (Eu) - RL
95 M5 (Eu) - RL
#2529402 - 02/08/12 10:55 AM Re: Recommendation: Front Pads for 2008 BMW 528xi [Re: nleksan]
barlowc Offline
My brother was asking what I thought of this POWERSTOP Extreme Performance Brake Disc and Pad Kit. He's keen on the look of slotted/drilled rotots.
I can't remember where I saw them, but last night I also saw plain Brembo rotors for a reasonable price.
RockAuto has StopTech Street Performance pads and Centric SportStop Drilled and Slotted rotors which would be $325 shipped.
Thoughts on those options?
Edited by barlowc (02/08/12 11:03 AM)
#2529457 - 02/08/12 11:47 AM Re: Recommendation: Front Pads for 2008 BMW 528xi [Re: barlowc]
SteveSRT8 Offline
Loc: Sunny Florida
Stoptech has a terrific pad formula for their performance kits. If that is what you're looking at look no further. It's a proprietary product and is the BEST blend of performance and manners I've ever used on my car. Note that I have 4 piston fixed Brembos on all 4 wheels.
Drilled rotors are for bling only, DO NOT use them unless you are just looking for looks.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#2529513 - 02/08/12 12:39 PM Re: Recommendation: Front Pads for 2008 BMW 528xi [Re: SteveSRT8]
barlowc Offline
Sorry, my previous link was the wrong one. It should have been this. POWERSTOP Extreme Performance Brake Disc and Pad Kit.
Page 1 of 3 1 2 3 >
