Analysis performed by Blackstone Labs 2/27/06
EQUIPMENT MAKE: 2003 Mercedes Benz E320
EQUIPMENT MODEL: 3.2L V-6
FUEL TYPE: Gasoline -- Unleaded
Miles on Engine: 53,581
OIL USE INTERVAL: 14,521 Miles
OIL TYPE & GRADE: Mobil 1 0W/40
MAKE-UP OIL ADDED: 0 qts
PAUL: It looks like you onboard computer is directing you in the proper manner. Universal averages show typical wear from this type of engine after 7230 miles on the oil. Your wear metals pretty much beat most of those averages after your 14,521 miles on the oil. The TBN was 2.7, some active additive left. 1.0 is low. We found a bit of fuel but it didn't hurt anything. We worry when it goes over 2.0%. Silicon was okay at 10 ppm so the air filter is getting the job done. Looking good! We think you can trust the oil change monitor light.
Numbers on right are universal averages:
ALUMINUM 5 5
CHROMIUM 0 1
IRON 12 16
COPPER 7 6
LEAD 2 6
TIN 0 1
MOLYBDENUM 62 51
NICKEL 0 0
MANGANESE 3 3
SILVER 0 0
TITANIUM 0 0
POTASSIUM 0 1
BORON 66 76
SILICON 10 10
SODIUM 4 6
CALCIUM 2203 2298
MAGNESIUM 86 272
PHOSPHORUS 688 794
ZINC 767 907
BARIUM 0 0
Numbers on the right are “should be values”
INSOLUBLES% = 0.3 WATER% = Trace 0.1
ANTIFREEZE% = 0.0 0.0
FUEL% = FLASHPOINT IN ºF = 375 >375
SUS VISCOSITY @ 210 ºF = 69.3 65-76
I also had the MB "Lifetime" ATF tested and will post on the ATF forum.
ALUMINUM 5 5
CHROMIUM 0 1
IRON 12 16
COPPER 7 6
LEAD 2 6
TIN 0 1
MOLYBDENUM 62 51
NICKEL 0 0
MANGANESE 3 3
SILVER 0 0
TITANIUM 0 0
POTASSIUM 0 1
BORON 66 76
SILICON 10 10
SODIUM 4 6
CALCIUM 2203 2298
MAGNESIUM 86 272
PHOSPHORUS 688 794
ZINC 767 907
BARIUM 0 0
