I’ve found a used Suzuki manual transmission and transfer case with only 18,000 miles of use. I’m told that these two gear boxes have been sitting in storage for the last decade or two. I've just installed them in my restoration project, a 1989 Sidekick.
I believe that the transmission and transfer case contain copper alloy components that will be attacked by olefin sulfide additives in GL-5 gear oils. My aged service manual specifies SAE 75W90 GL-4 gear oil for these two antiques.
While this requirement can be satisfied with Amsoil and Redline GL-4 products, I want to use GL-5 gear oils that contain borate additives in place of sulfide additives. The only product that I have found is Chevron Delo Gear Lubricant ESI 80W90, which is non-synthetic. Unfortunately, my service manual approves of SAE 80W90 gear oil only when the temperature remains above minus 4 degrees Fahrenheit – a dicey proposition during a Colorado winter.
What lighter GL-5 gear oils without sulfide additives are available for my application?
