ProGauge PGO-4612 Oil Filter??
by andrewp1998
02/07/16 01:11 AM
Filter efficiency and diminishing returns
by ToadU
02/07/16 12:19 AM
Change PP after 1000 mi 6 month Short Winter Trips
by WillsYoda
02/07/16 12:00 AM
Tread Life & Curvy Roads
by Nick1994
02/06/16 11:46 PM
What paper engine air filter do YOU recommend?
by Georgiey22
02/06/16 11:20 PM
Power Steering Problems.......
by qwerty1234
02/06/16 10:58 PM
CLR repair of completely blocked heater core/hose
by DoubleWasp
02/06/16 10:55 PM
FS Ford racing Fiesta exhaust system
by mv6845
02/06/16 10:27 PM
Inner Tie-rod removal
by Sawdusted
02/06/16 09:54 PM
What's a good price for a 2013 4Runner?
by Gebo
02/06/16 09:34 PM
Chrysler 42LE - avoid synthetic gear lubes
by Wampahoofus
02/06/16 09:15 PM
Nose mask (car bra) tab repair
by aquariuscsm
02/06/16 08:53 PM
Nazmorgul, bhans, truthtracer, Recreator, 18LateModelFan
56842 Registered Users
29 registered (Astro14, B320i, alan003, akela, AutoCoil, 2015_PSD, 1 invisible), 495 Guests and 197 Spiders online.
56842 Members
66 Forums
244346 Topics
Page 1 of 4 1 2 3 4 >
#2524964 - 02/04/12 07:37 AM High-temp oil for turbo car
Jarlaxle Offline
Loc: New England
Posting this at my wife's request: She has a very-highly-modified 1986 Buick Grand National. It's parked for the winter, but a driver in warm weather. The engine is a fire-breathing Stage II stroker (272ci) V6 that put over 700HP down at the wheels (easily 800+ at the crank). As you might expect of a turbo engine making better than 3hp/ci, it's pretty brutal on oil. We have done what we can (big oil cooler, oversized Chevy MDT oil filter, big oil pan), but even with all this, it still sees oil temps over 300 degrees and has topped 350. (Pre-cooler, it pinned the gauge at over 400!)
I think the current fill is 5W-50, I think Castrol Syntec, that being the only 5W-50 we could find on anything like a regular basis. What's in the car was the last of what we had, so we will need to switch. Any suggestions? Mobil or Rotella 5W-40 would seem like it might work...?
1979 Coupe de Ville, 542 stroker, parked for winter frown
2011 Crown Vic P71, 5W-20 Mobil, NAPA Silver
2012 Suzuki AN400A, parked for winter frown
#2524968 - 02/04/12 07:44 AM Re: High-temp oil for turbo car [Re: Jarlaxle]
JHZR2 Offline
Loc: New Jersey
This is where an ester oil comes into the picture, I'd grab the redline with highest HTHS.
With those mods to support the oil longevity, and temperatures, IMO, the car is not designed to make such power. I doubt you would notice a difference dialing it back a few hundred for most uses.
#2524970 - 02/04/12 07:49 AM Re: High-temp oil for turbo car [Re: Jarlaxle]
d00df00d Offline
Loc: PA
There is a Mobil 1 5w-50 that you should be able to get through Mercedes, Lexus, and possibly Porsche dealerships. I'd use that over Syntec 5w-50 or any xw-40 on the shelf, honestly.
There is also Castrol TWS 10w-60, which definitely is available in large quantities through any BMW dealership.
Both of those oils are race-bred and designed to take very, very high temps -- more than any oil you'll find on the shelf.
EDIT: I second the suggestion to consider Red Line, but it usually isn't available in stores. If you're going to consider online or phone ordering, also look at RLI and Motul 300V.
EDIT 2: OP, have you considered a liquid heat exchanger for the oil?
2011 Mazda RX-8 R3
Castrol GTX 5w-20
#2524982 - 02/04/12 08:14 AM Re: High-temp oil for turbo car [Re: Jarlaxle]
JRed Offline
Loc: Virginia
How about M1/Bradd Penn/Valvoline Racing/etc. 15w-50?
No sense going for a 5w or 10w oil when the car is only being driven in warm weather.
06 Subaru Impreza WRX - Sold. The only mechanical thing I'll ever love.
07 Toyota Prius - Cheap synthetic and PureOne filters.
#2524983 - 02/04/12 08:14 AM Re: High-temp oil for turbo car [Re: Jarlaxle]
SteveSRT8 Offline
Loc: Sunny Florida
for anything that high output you have to go Dominator.
A real race oil that actually wins races.
FWIW I run it in a very expensive blown Chevy BB stroker in a go-fast boat. Excellent results per oil analysis.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#2524987 - 02/04/12 08:23 AM Re: High-temp oil for turbo car [Re: Jarlaxle]
aquariuscsm Offline
Loc: South Texas,USA
My favorite car of all time!slobber
Spare no expense on that beast! Redline,Amsoil,or Royal Purple 50 weight.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Syntec 10W40/Fram Ultra
Amsoil MTG(tranny)
Amsoil 80W90 GL5(rear diff)
Mobil 1 ATF
Redline Water Wetter
#2524999 - 02/04/12 08:34 AM Re: High-temp oil for turbo car [Re: Jarlaxle]
Roadkingnc Offline
Loc: NC USA
If you dont have a cat run mobil1 0w50 racing oil, it will take anything that engine can throw at it
#2525009 - 02/04/12 08:40 AM Re: High-temp oil for turbo car [Re: Jarlaxle]
JAG Offline
Loc: Fredericksburg, VA
Those are oil temps that engines are not supposed to operate at so I'd use Redline xW-50 because of the high thermal stability, low volatility, and high HTHS viscosity. I would not use any oil that is mostly Group III.
#2525010 - 02/04/12 08:43 AM Re: High-temp oil for turbo car [Re: JAG]
fxrider Offline
Loc: Wyoming
Mobil-1 5w50 is on sale @ k-mart fyi
#2525018 - 02/04/12 08:56 AM Re: High-temp oil for turbo car [Re: Jarlaxle]
NHGUY Offline
Loc: USA
Wow,does this even have any emissions hardware still installed? By rights,visual inspection is still required even in (Calif standards) New England.
#2525031 - 02/04/12 09:13 AM Re: High-temp oil for turbo car [Re: SteveSRT8]
Turk Offline
Loc: MN
Yes, this or Redline.
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
#2525037 - 02/04/12 09:17 AM Re: High-temp oil for turbo car [Re: Jarlaxle]
knerml Offline
Loc: NE Ohio
You might want to look at VW502.00 spec synthetic oils. They for formulated for turbo engines. Examples:
- 5W40 Syntec/Edge
- 0W40 Mobil 1
2011 Kia Sorento 2.4 Shell/QS/PZ 5W20 Syn OEM Filter
2015 Hyundai Elantra Sport 2.0 GDI Shell/QS/PZ 5W20 Syn OEM Filter
#2525049 - 02/04/12 09:37 AM Re: High-temp oil for turbo car [Re: d00df00d]
The_Eric Offline
Loc: Iowa
This is a good suggestion. I know that it were mine, I'd be investigating ways to lower the oil temp.
How is the car driven normally? What are the bearing clearances like? Those temps seem a bit high if you're out of the throttle a lot. Also, what are your hot oil pressure readings?
While I'll freely admit that my experience with big power turbo cars is quite limited, as I'm sure your aware, that engine isn't making 700hp all the time and I would expect the heat to be a bit more manageable while off the loud pedal.
EDIT: As for an oil recommendation, I'd say, Red Line, RLI or Amsoil. Any of these places you can call and get a knowledgeable person to help you purchase the correct product from their line.
Edited by The_Eric (02/04/12 09:39 AM)
2001 Hyundai Elantra 2.0
1998 Chevy Malibu 2.4
1995 Pontiac Grand Am 3.1
1979 Ford F-150 351M
#2525059 - 02/04/12 09:52 AM Re: High-temp oil for turbo car [Re: Jarlaxle]
dparm Offline
Loc: Chicago, IL
Just curious if you run an oil temp & pressure gauge to verify the oil type?
2011.5 BMW M3 saloon ZCP
Castrol Edge Professional TWS 10w60 + Mahle OX 254D3
#2525094 - 02/04/12 10:38 AM Re: High-temp oil for turbo car [Re: Jarlaxle]
chubbs1 Offline
Loc: Merritt Island FL, USA
I third or fourth the RedLine, Amsoil suggestion. These are two companies with a lot of races under their belts, with highly modified engines under extreme environmental pressure.
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
