What is piston slap?
Lexington, KY
Also what kind of sound does it make? Does it go away as the engine warms up. I have been told my BMW has some piston slap at 210,000 miles and I should not worry about it.
Typical slap starts when the car is started, then quickly fades. One of our trucks with 400k miles on it has done it since new.
We own a lot of 'slappers', GM V8's, and they have proven to be very reliable for many hundreds of thousands of miles.
A knocking noise.
Yes.
That's correct; it's no cause for concern, just annoying.
My understanding is that piston-slap incidents have increased in recent years as engine designs have changed to suit emissions and gas-mileage laws.
Oh man, my 2000 Sierra 5.3L has Piston Slap so bad.....
I traded it in for a 2003 and during the eval they did I made sure it was quite warmed up.
Here is a great website about GM's piston slap.
GM's Piston Slap
Here is their definition:
Piston slap is nothing new to piston driven internal combustion engines and compressors. It is the secondary (sideways or perpendicular) movement of a piston against the side of a cylinder bore where the primary movement of a piston is intended to be parallel (up and down) to the cylinder bore. All piston driven internal combustion engines and compressors have a certain amount of piston slap.
Excessive piston slap occurs when the clearance between the piston and the cylinder bore is too great. The piston to cylinder bore clearance becomes too great either through wear, mismatched pistons and cylinder bores at manufacturing or, a combination of both. The audible noise associated with excessive piston slap is due to the perpendicular impact of the piston against the wall of the cylinder bore. Audible piston slap is typically loudest when the engine is first started up. The pistons then expand with heat reducing the piston to cylinder bore clearance thus, reducing the perpendicular impact of the piston against the cylinder wall and its resulting noise.
Basically it's your piston(skirts,very bottom edge)rocking back and forth in the bore when the piston is traveling up and down, the piston to bore clearance is too great. Usually once up to operating temp piston swells takes up that loose tolerance and the noise stops.
it's nothing to be overly concerned about.
Some Honda engines get piston slap when they get hot. The clearance cold is .0008 and the piston shrinks as it warms to provide adequate gap between pistion and cyl wall. Most pistons expand with heat and thus the noise at start up goes away as the engine warms.
What magical material is Honda making pistons out of that shrink as they heat up? Ice, quartz, cubic zirconium tungstate?
Hypereutectic pistons (AA 4032 or similar) still expand as they warm up.
But if you have piston slap because your piston to bore clearance is high then that implies your compression is being lost; correct???
Why would that not be a problem???
Because it quickly goes away?
The trend for it happening in more recent years appears to be because of the increasing short piston skirts. Compare an old SBC or SBF piston to one from an LSx or Modular and the height difference is HUGE.
It can be a sign of wear. But most of it is coming from piston design and clearances.
Note that just because the engine slaps a bit does not mean any compression is lost. The rings do the sealing and oil control, our vans that slap use no oil and do not smoke... even with 400,000 miles.
Huh??
No.
What? You didn't know that Honda has their own proprietary aluminum alloy that SHRINKS when heated?
In the frozen North these engines can't even be started!
I don't know if it is piston design or cylinder material, but when you start at .0008 you can't expand very much. I'd imagine it's a little of both.
