Originally Posted By: Tegger
Originally Posted By: womcat
Well my thought was the truck would warm up faster because there wouldn't be as much cold air flowing. Even with the fan clutch, there is always some air movement.
True, but that's AIR through the rad. With the thermostat closed, there is no WATER flow through the rad, and that's what counts. It does not matter what happens to the water that's stuck in the rad, or how cold you make it, so long as it doesn't freeze.
The thermostat's job is to keep the block up to temperature. It does this by refusing to allow water flow through the rad unless coolant temperatures warrant.
In very cold weather, as long as the vehicle is in motion, it's even common for the thermostat NEVER to open, and the rad NEVER to get used, even during long drives. In very cold weather, it's often sufficient for heat to be removed by radiation into the surrounding air, and from the heater core.
But when the vehicle is stationary, there's no air moving through the engine bay, and heat-transfer slows down
dramatically. That's when the thermostat might open, and you'll need the rad and fan to kick in and prevent overheating.
As for the gauge reading, I don't know about your truck, but many vehicles have separate sensors for the computer and for the gauge. The only way of telling how hot an engine is getting is with an infrared thermometer, commonly and cheaply available.
I know how all that works, but I was thinking in the winter the fan isn't really needed very much. When it's cold, it doesn't take hardly any vehicle speed to provide enough air through the radiator to cool it down. Obviously it means you can't sit for long periods not moving though, which I completely forgot. I know some of the newer trucks have an electric fan, which is nice. No need to be spinning a fan all the time when it's only needed once in a while. I know mine has a clutch, but it still spins quite a bit.
I was also thinking it might make a mpg difference on a smaller motor. I did return my best highway mileage on a long trip right after I left it off. Too many variables though to completely attribute it to the lack of the fan.
Also, no comment as to why I was stopped with the truck running and no lights on
