I googled it first hit was a factory manual
recommending
"Check the fluid level with the rear
differential at normal operating
temperature and the vehicle sitting
on level ground. Remove the
differential fluid filler bolt and
washer and carefully feel inside the
bolt hole with your finger. The fluid
level should be up to the edge of the
bolt hole. If it is not, slowly add
Honda Dual Pump Fluid until it
starts to run out of the hole. Reinstalll
the filler bolt and tighten it securely.
If the Dual Pump Fluid is not
available, you may use Honda
Premium Formula Automatic
Transmission Fluid (ATF) or a
quality DEXRON® III ATF as a
temporary replacement. However,
continued use can cause noise,
vibration and performance problems.
Have the differential drained and
refilled with Honda Dual Pump Fluid
as soon as it is convenient.
The rear differential should be
drained and refilled with new fluid
according to the time and distance
recommendations in the maintenance
schedule.
Maintenance"
https://techinfo.honda.com/rjanisis/pubs/om/CR0101/CR0101MAINIDX.pdf
google is your friend... sometimes
