Wrong Dipstick? Honda Accord 2.4 Reading Low
by ThirdeYe
05/30/16 09:09 AM
radiator hose install, 08 Matrix.
by JustinH
05/30/16 08:56 AM
Bendix CT-3 Brake Pads
by RevelationLion
05/30/16 08:38 AM
Ever Have A Funniest Home Video Moment?
by coopns
05/30/16 08:20 AM
Parties
by AirgunSavant
05/30/16 08:02 AM
Static electricity accumulation of earth and human
by yvon_la
05/30/16 07:26 AM
18.14F this morning....
by Shannow
05/30/16 06:09 AM
Why it's a bad idea to ignore wheel-bearing noises
by Tegger
05/30/16 03:29 AM
Water decarbonization, does it work?
by FordCapriDriver
05/30/16 01:56 AM
Do I need a better tire for PNW trip?
by The_Eric
05/29/16 11:51 PM
Turtle Beach PC headset hack
by asand1
05/29/16 11:34 PM
Lengthy question for the seasoned oil gurus
by Jetstreamz06
05/29/16 11:10 PM
Welder_Repairman, saredX, Corraun, kevinstoyhauler, jimx1169
58022 Registered Users
100 registered (Al, Astro_Guy, AnthemBassMan, 2015_PSD, AirgunSavant, Bandito440, 10 invisible), 1604 Guests and 298 Spiders online.
58022 Members
66 Forums
249591 Topics
Page 1 of 2 1 2 >
#2503930 - 01/24/12 01:27 AM Hyundai Trajet Automatic Transmission problem
Dave1944 Offline
Loc: Johannesburg South Africa
My Hyundai Trajet 2.7 v6 automatic gearbox is slipping between gears. It has 230000 kms on the clock. I have no idea if and when last the ATF was changed as I bought it used no FSH. Fluid is slightly brown. Im thinking of doing an ATF oil change before having it checked at the agants or specialist shop. Am I wasting money doing this anybody got some thought on it
#2503938 - 01/24/12 01:48 AM Re: Hyundai Trajet Automatic Transmission problem [Re: Dave1944]
toyota62 Offline
Loc: Australia
Possible three things.Defective input or output speed sensors or TP sensor.Pretty common.Before do anything please check Any DTC's current or history set in the PCM.
Bob.
AIAME
2012 Rav4 Mobil1 EP 0w-20
2016 c250 diesel Mobil1 0w-40
#2503939 - 01/24/12 01:57 AM Re: Hyundai Trajet Automatic Transmission problem [Re: toyota62]
Dave1944 Offline
Thanks for the advice. Can I do thees myself or must agent do these checks. Sorry I am a not too technical so what are DTC's and PCM's
#2503949 - 01/24/12 03:54 AM Re: Hyundai Trajet Automatic Transmission problem [Re: Dave1944]
229 Offline
Loc: Mid Atlantic
You will need a scanner. Let a specialist shop do it.
Eneos Dealer
#2503950 - 01/24/12 04:00 AM Re: Hyundai Trajet Automatic Transmission problem [Re: Dave1944]
toyota62 Offline
Loc: Australia
Hi Mate.
If you have a OBD scaning tool then you can do it.But better take the vehicle to the local garage and ask them to check the trouble codes.Also PRNDL switch also a common problem in your model.(With out checking the codes we are just guessing here.)
Complete ATF change also a good idea.
Cheers.
Bob.
Bob.
AIAME
#2507010 - 01/27/12 03:35 AM Re: Hyundai Trajet Automatic Transmission problem [Re: Dave1944]
Dave1944 Offline
Thanks for suggestions have contacted a Hyundai approved repairer who suggested I bring the vehicle in. I subsequently found fluid level a bit low and asked what fluid to use just to top up. I was told Castrol Transmax Z which is green and not red like normal ATF. Manual says to use SP111 which I cant find. Hyundai Dealership also uses the Transmax Z. Any thoughts on the Transmax Z.
#2507128 - 01/27/12 08:11 AM Re: Hyundai Trajet Automatic Transmission problem [Re: Dave1944]
MobilinHyundia Offline
Loc: Ontario, Canada
Castrol Transmax Z is not SPIII approved.
2009 Sonata GL 2.4L (185 000km)-AMSOIL 0W20 ,FRAM ULRA oil filter
2009 Sonata LTD 2.4L (111 000km)AMSOIL 5W20, Amsoil filter
24 000km oci so far
#2507280 - 01/27/12 10:34 AM Re: Hyundai Trajet Automatic Transmission problem [Re: Dave1944]
JTK Offline
Loc: Buffalo, NY
What model year? If it's a 4spd auto, it's most likely an F4A51 trans. These transmissions require an ATF suitable for Hyundai/Kia SPIII use. They're easy to service. There's a bottom mounted drain plug and you add new fluid through the dipstick tube. I'd first try a drain/fill to see if that helps.
Some of the early models (2001, maybe 2002) had a top mounted spin-on trans filter. If there's no external filter, there's nothing else to service. There's an internal filter that requires removal of the valve body to replace.
Also- do the PRNDL lights on the dash, coincide with the floor shifter? If not, there could be range/mode sensor issues that could cause shifting issues. That's a fairly easy repair to replace the sensor.
Joel
Edited by JTK (01/27/12 10:36 AM)
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#2527010 - 02/06/12 08:53 AM Re: Hyundai Trajet Automatic Transmission problem [Re: JTK]
Dave1944 Offline
IT IS A 2005 MODEL 4 FOREWARD SPEED AUTOMATIC BOX, INCLUDING THE OVERDRIVE. BOTH HYUNDAI AGENT AND HYUNDAI APPROVED BOX REPAIRER USE CASTROL TRANSMAX Z. I DONT BELIEVE THE GEARBOX IS SLIPPING BECAUSE WHEN ACCELERATING THE BOX SHIFTS EFFORTLESSLY. ONLY WHEN DECELERATING OR COASTING THE BOX CHANGES TO LOWER GEAR PREMATURELY SO WHEN YOU ACCELERATE AGAIN IT IS WRONG GEAR. AM TRYING TO AVOID EXPENSIVE "STRIP & QUOTE" SO AM TAKING IT FOR COMPUTER DIAGNOCTIC CHECKS TO SEE IF IT IS SPEED CENSORS OR SOMETHING ELSE ELECTRONIC
#2527014 - 02/06/12 09:01 AM Re: Hyundai Trajet Automatic Transmission problem [Re: JTK]
Dave1944 Offline
JTK IT IS A COLUMN SHIFT NOT FLOOR SHIFT AND GEAR POSITIONS COINCIDE WITH DASH INDICATOR. ITS NOT SO EASY TO MANUALLY SHIFT INTO 2 AND 1.
#2527105 - 02/06/12 10:37 AM Re: Hyundai Trajet Automatic Transmission problem [Re: Dave1944]
JTK Offline
Loc: Buffalo, NY
Possible vehicle speed sensor (VSS) problem?
Like said, the F4A51 will set it's own diagnostic codes, but if one is set, your check engine light will usually be lit to show this.
Joel
#2529174 - 02/08/12 07:08 AM Re: Hyundai Trajet Automatic Transmission problem [Re: JTK]
Dave1944 Offline
Thanks Joel
Will let you know what transpires once I have had all the diagnostics done.
#2536092 - 02/14/12 09:28 AM Re: Hyundai Trajet Automatic Transmission problem [Re: Dave1944]
Dave1944 Offline
Hi Joe, my Trajet does not appear to have a check engine light is this normal. Anyway I had the diagnostics checked and a PO120 (Throttel Position Sensor)DTC came up. Technician at the Hyundai approved repair centre maintains this could be the problem. They are now wiating for a replacement part. Will do a ATF flush and refill at same time. Once again they confirmed they use Castrol TRansmax Z. As approved repairer they should know what to use.
Edited by Dave1944 (02/14/12 09:31 AM)
#2536109 - 02/14/12 09:39 AM Re: Hyundai Trajet Automatic Transmission problem [Re: Dave1944]
JTK Offline
Loc: Buffalo, NY
Good deal!
TPS problems are fairly common on the Hyundai 2.7 and 3.3L. If yours has electronic throttle control, I'm surprised you've never been left in 'reduced power mode' when the TPS acts up. That's the typical result. You'll get just enough throttle control to get off the road.
Joel
#2552095 - 02/29/12 08:12 AM Re: Hyundai Trajet Automatic Transmission problem [Re: Dave1944]
Dave1944 Offline
Hi still the problem persists. They replaced the TPS sensor and after test driving the DTC still showed the TPS sensor with a fault plus a few others. After spending a week at the gearbox "Experts" with only a list of faults to be attended to by Hyundai, the vehicle was taken to Hyundai. After another week of fiddling with the electrics, cleaning connections etc I was told no more error codes were found. The problem has still not been resolved so its going back on Friday. I give up!
Page 1 of 2 1 2 >
