Volkswagen Looks to Build Its Own ‘Gigafactory’
by HTSS_TR
05/27/16 04:55 PM
QSAD 5W20 UOA 5,504 miles 2011 TAURUS 3.5
by dustyroads
05/27/16 04:48 PM
Why you need a dash cam
by Rand
05/27/16 04:12 PM
Performance exhaust question
by 007
05/27/16 04:08 PM
Positive results with BG109
by rainman49
05/27/16 03:11 PM
I have have put a lot of thought into this oil.
by Mathew_Boss
05/27/16 02:45 PM
CARQUEST Premium Oil Filter
by AirgunSavant
05/27/16 01:40 PM
The world's most harrowing route to school
by HTSS_TR
05/27/16 01:18 PM
STP 3614 Purolator cut and view
by sprite1741
05/27/16 12:58 PM
Finally saved up and bought my 1st car
by rocky8314
05/27/16 12:33 PM
Yellow dot and valve stem alignment
by qdeezie
05/27/16 12:30 PM
Shipping from Amazon
by grampi
05/27/16 12:14 PM
LEVY, Timmytimmy, Peakboy91, TimingBeltKing, watergate528
57997 Registered Users
72 registered (2oldtommy, aquariuscsm, 01_celica_gt, AlienBug, afree, 901Memphis, 3 invisible), 1741 Guests and 316 Spiders online.
57997 Members
66 Forums
249492 Topics
Page 1 of 3 1 2 3 >
#2499299 - 01/19/12 02:45 PM Car Cranks, Won't Start
InvalidUserID Offline
Loc: Bay Area, CA
So on my girlfriend's 2001 V6 Mustang, she's been having starting issues.
It started a few weeks ago, the car will crank fine but won't start. After trying 3-4 times, I tried her spare key and it worked. Thought it was just the key.
A few days ago, she said it wouldn't start at work. Same thing: cranks but won't start. She finally got it to start after a few tries. I had her take my car, and I tried her car next morning and it started right up. A few hours later, we tried to move it and it cranked but wouldn't start.
So:
- Battery is less than a year old, 12.5V
- Alternator puts out 14.2V
- Car seems to start fine in the morning/first start, but won't afterwards/2nd start.
- I'm pretty sure I can hear the fuel pump when turning the key to "ON".
- Distributor-less system
What should I be looking for?
My Cars aka old reliables:
- '96 Camaro 3800 II
- '97 4.0 Grand Cherokee
- '99 Civic EX
#2499305 - 01/19/12 02:51 PM Re: Car Cranks, Won't Start [Re: InvalidUserID]
Donald Online   content
Loc: Upstate NY
I would spray in a little starter fluid the next time it does not start. That will give you a clue as to spark or fuel.
Is it spinning over (based upon sound) at the right speed to start? Or really laboring?
Spark plug condition? Pull a plug or two and have a look?
Bad fuel?
Any CEL?
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- 4-sale
1999 Dodge Ram 2500 w/Cummins- 4-sale
#2499310 - 01/19/12 02:55 PM Re: Car Cranks, Won't Start [Re: InvalidUserID]
mechanicx Offline
Loc: Ohio
Assuming you do hear the fuel pump run, check for spark when you get crank and no start.
#2499320 - 01/19/12 03:05 PM Re: Car Cranks, Won't Start [Re: InvalidUserID]
Loc: Bay Area, CA
No CEL, I plugged in my scanner anyways, nothing.
Cranking fine and strong, sounds normal.
I think I can eliminate bad fuel as it's been about 2-3 tanks since the last starting issue.
Last time I checked the plugs, they looked normal. The car runs perfectly fine, it's just having starting issues right now.
I'm hoping the fact that it starts fine the first time but has a hard time hours after can help narrow it down.
- '99 Civic EX
#2499325 - 01/19/12 03:10 PM Re: Car Cranks, Won't Start [Re: InvalidUserID]
Quest Offline
Loc: beaver land EH?
remember the fundamentals:
fuel, air and spark.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#2499332 - 01/19/12 03:20 PM Re: Car Cranks, Won't Start [Re: InvalidUserID]
Loc: Bay Area, CA
Well, just tried to start it after letting it sit overnight, first attempt sounded like it almost turned over. 2nd and 3rd attempt it just cranks.
I had my scanner hooked up, before the first attempt, scanner showed fuel pressure at 42 and 0 after trying to start it. Fuel System 1 is "OPEN", don't know if that is normal or if that data helps.
I should add: 130,000 miles, all original parts (fuel pump, alternator/starter).
Edited by InvalidUserID (01/19/12 03:20 PM)
- '99 Civic EX
#2499359 - 01/19/12 03:54 PM Re: Car Cranks, Won't Start [Re: Quest]
45ACP Offline
Loc: Dallas Texas
Q.
You are in fact correct, but have been through this on a few cars and found that air is largely redundant (if it wont start with the intake manifold off, its likely something else and not at lack for "air.")
So, again, while correct, its techically "fuel, (air,) spark, and compression."
Blowed head gasket = less compression = can make car hard to start, sometimes takes ~10 minutes for compression to build.
Crank-no-start condition could be many things, but prime suspect is always fuel (starter fluid in intake manifold is good indicator, if it starts it should run for a couple seconds. Firsthand experience bore this out to diagnose Fuel Pump, next step is to take line off at back of engine to see if fuel comes up) and second suspect is spark/crank.
#2499362 - 01/19/12 03:57 PM Re: Car Cranks, Won't Start [Re: InvalidUserID]
45ACP Offline
Loc: Dallas Texas
Two things this sounds like, and what it "could be" since i have had a car that behaved similar:
Your fuel pump could be dying a slow death, and not putting out enough pressure to start the car reliably, every time. Pressure has to "build".
Very unlikely you have a head gasket (compression) issue. You would know if you did.
This would explain intermittent starts, as well as taking some time to start, then wanting to start then not starting. If it starts some minutes after it "anted to start" then "just cranks," it could be a dying but not yet deal fuel pump. They can last for some time in a marginal state. Had it happen on two vehicles, exactly that.
It might not be, but im thinking more and ore the fuel pump is in the way out (and is good enough to give good pressure readings "sometimes." They do that. It fools the diagnostic test...) Mine made a "hiccup" on the highway and i thought the car was going to stall, it held up for a month or so. Changed fuel pump? .. ran and started as new. 2cents
#2499380 - 01/19/12 04:11 PM Re: Car Cranks, Won't Start [Re: InvalidUserID]
eljefino Offline
Loc: ME
Could be an anti theft issue. IDK if the key is related at all like it is on some GMs. You'd have a blinky light on the dash most likely.
#2499384 - 01/19/12 04:16 PM Re: Car Cranks, Won't Start [Re: eljefino]
thr_wedge Offline
Loc: Texas
I was thinking the same thing.
Does the spare key always work?
#2499385 - 01/19/12 04:16 PM Re: Car Cranks, Won't Start [Re: eljefino]
Rand Online   content
Loc: NE,Ohio
usually with the ford anti-theft it doesnt crank at all? at least the older ford system.
and you get a solid light.. at least thats what it did with my ranger with the PATS system.
+3600 marginal fuel pump.
doubt its a head gasket.. and I'm not sure how a head gasket could make it take 10min to get compression? you have a fresh compression cycle 5? times a second?
I would verify spark during the no start condition then go to the fuel system.
Edited by Rand (01/19/12 04:18 PM)
2015 Forester I-Premium 6MT
#2499387 - 01/19/12 04:19 PM Re: Car Cranks, Won't Start [Re: 45ACP]
Warstud Offline
Loc: MIchigan
Sounds like it to me.
#2499459 - 01/19/12 05:49 PM Re: Car Cranks, Won't Start [Re: InvalidUserID]
toneydoc Offline
Loc: War Eagle
How old is the fuel filter? I had a car refuse to crank due to bad fuel filter.
1994 Jeep 146k Castrol 0w40
2014 Camry 14k TGMO 0w20
2010 Sebring 39k Valvoline 5w30
2014 HD Ultra 16k Valv20w50
2012 Toyota Rav4 22k Mobil 1 0w30AFE
#2499461 - 01/19/12 05:51 PM Re: Car Cranks, Won't Start [Re: Rand]
45ACP Offline
Loc: Dallas Texas
Offtopic, but.. I doubt it is a HG issue as well. What i was referring to that when i had a car with a slowly failing head gasket, something with either the loss of compression in one/more cylinders or the exhaust gas gettin where it wasnt made the car crank slowly and not start, then require waiting for it to build enough compression to fire and run. (Similar to starting a car with 20W-50 when its freezing out, slow engine revolution and wont fire. Something was impeding it. Then it turns faster some minutes later.) Eventually the engine did fail by dropping a valve. Before that i had absolute milkshake oil twice, and was tough to start the car and smoke would come out the tailpipe. It died a slow death and almost almost left me on the side of the highway, and the cars last ride was a 0 to ~60MPH acceleratio full of sputtering that took a good two minutes, black/grey smoke behind me the whole time. It dropped its valve roughly 6 starts later, 12 hours later that night... on the other side of the same highway. So, it can impact engine starting. HG was supect, but the cylinder had a valve shaped hole in it upon disassembly.
If the head gasket were to have a slow leak that was getting bigger but not large enough to be full-on obvious and masked by cold weather i.e. smoke signale etc etc and was in fact a small leak, it could be beginning to affect compression enough to inhibit starting due to what was leaked where. I dont think that is happening here, but was a thought. Bubbling coolant sometimes wont bubble enough to be seen and the antifreeze smell of the exhaust and plume can be attributed to cold weather. Just my 2cents
#2499462 - 01/19/12 05:53 PM Re: Car Cranks, Won't Start [Re: InvalidUserID]
45ACP Offline
Loc: Dallas Texas
Hey, OP.. is that distributor cap on tight? That could be your issue right there as well! Spark-related. Could be as simple as tightening two screws, if you can move the cap with your hand that could be your issue right there. Had that happen too whistle
Page 1 of 3 1 2 3 >
