I am full of firsts here...
First post here, and I bring with me my first ever UOA report with a strange twist...
Flashpoint = 350F
Fuel = 0.8%
Insolubles = 0.4%
No antifreeze or water
No makeup oil
TBN 4.0
6881 kilometres on oil for over 6 months
This is also my first ever synthetic fill, no flush was done, and is also the first oil change that I did myself.
I have K&N air filter and two magnets stuck to the oil pan. The sample was drawn out of dipstick hole after a highway trip.
This is my extended drain experiment. Manual OCI is 6000km/6mos. Goal is 8000. One year is even better. Car is our of warranty now.
It is this comment from Blackstone that is highly puzzling:
Sus Viscosity @ 100C = 57.0code:
ALUMINUM 2
CHROMIUM 1
IRON 22
COPPER 4
LEAD 29
TIN 0
MOLYBDENUM 65
NICKEL 0
MANGANESE 5
SILVER 0
TITANIUM 0
POTASSIUM 0
BORON 96
SILICON 8
SODIUM 5
CALCIUM 2757
MAGNESIUM 22
PHOSPHORUS 785
ZINC 902
BARIUM 0
Flashpoint = 350F
Fuel = 0.8%
Insolubles = 0.4%
No makeup oil
TBN 4.0
What is the deal with my lead???quote:
We are a little surprised at the amount of lead (bearings) found in this sample. Comparing your wear to universal average levels (based on this type engine after a 4,625 mile oil use run), you can see lead, from bearings, is at several times the average level. One possible cause of this is the gas in the oil (0.8% of the sample) or possibly there is a compatibility problem with the synthetic base in this type oil. 4-ppm lead would be normal for this sample. We should know more about the cause of the lead in the next sample.
