Other than physical size, are there any other differences? I ask because I have a 1992 Chevrolet Lumina with a 3.1L and a 2003 GMC Safari with a 3.4L that spec either a PF47 or a PF52 depending on model year.
The 1st Gen Lumina platform didn't change between 1990-1994. By application a PF52 is specified for 1990-1992. In 1993-1994, a PF47 is specified.
The Safari platform was essentially the same between 1985-2005. There were some changes made in 2003 and continued through 2005 (6-lug, 16-inch wheels for instance). From 1985-1999 a PF52 was specified. From 2000-2005 a PF47 was specified.
I've used both filters on both cars without issue. However, I still wonder why the change in specified filters? It can't be chassis clearance issues. The change doesn't track with any kind of internal engine changes either (as far as I can tell).
