Originally Posted By: ahoier
With all the wiper blade complications, I'm tempted to just go "command-o" - i.e.: wiper blade-less....haha. I hear some people "swear" up and down about the Rain X weather beading paste stuff that you buff on, let set, then wipe off.....and it's supposed to bead the water off the windshield, etc....
My recent windshield wiper dillemma occured during a rain storm from Orlando International Airport
The driver side wiper stopped working during a light drizzle.....so thanks to my front-row bench seating, I kinda slid over to the middle seat, and was driving while looking out the passenger windshield which was swiping fine! haha. yea...kind of dangerous
Got home, mentioned it to a friend, he took my wiper arm apart, he was suspecting bad motor, but I was like...surely if the motor went out, BOTH wipers would stop working.....right?
So, he took the whole arm off, I flipped the wiper on, and the motor seems to be working fine......I'm not sure about the inner workings of the wiper arms.....? But he said it looks like the rivets broke off on my driver side....cause with the wiper switch on, the little knob that the wiper arm sits on twists back and forth......BUT, it will not make the wiper blade rotate when switched on.....he told me "in layman's terms" it's not "catching".....
So, what's the dillio..? Do I need a new arm...? or....is there a way of "fixing" the apparently broken "rivet" that isn't "catching" the arm...?
If you can get to it a small bolt and nut with a jam nut attached to prevent coming apart would fix the arm attachment problem. Just remember to leave the first nut a little loose to prevent binding of the arm before tightening the 2nd jam nut up. By the way after a little tweaking on the wiper arm it seems to be better time and a couple rain showers will tell.
