Myliftstand alternative jack stand
by momo
06/26/16 03:33 PM
Kmart sale on Smitty's oil and ATF
by slacktide_bitog
06/26/16 02:53 PM
Napa master pack oil filter price
by Electromotive
06/26/16 02:39 PM
Local Big Lots still has Valvoline next gen 10w30
by Electromotive
06/26/16 01:25 PM
Best Value Differential Oil 75W-90
by KevinP
06/26/16 01:02 PM
kohler 17hp . changed oil , now will not run
by chad8
06/26/16 12:32 PM
Oil change recomendations for '11 Ranger 2.3 Liter
by ryan2022
06/26/16 11:49 AM
Suggestions for 94 Lexus LS400 ATF
by Gasbuggy
06/26/16 11:23 AM
GOST Diesel fueln
by m37charlie
06/26/16 11:10 AM
Old interesting finds
by car51
06/26/16 10:53 AM
Filling nail holes in drywall
by Drew99GT
06/26/16 10:47 AM
1987 ford 460 motorhome, which oil to use?
by digler
06/26/16 10:30 AM
Ruturaj, derfderfgoose, ssnead, mtrev, redtacoma
58277 Registered Users
75 registered (1foxracing, BigD1, b1amgm47, 87sammy, BrocLuno, 2015_PSD, 10 invisible), 2031 Guests and 10 Spiders online.
58277 Members
66 Forums
250840 Topics
Page 1 of 2 1 2 >
#2494712 - 01/15/12 07:22 PM Used engine oil instead of WVO?
zyxelenator Offline
Loc: Louisville,KY
Just had a thought before I went to sleep last night. Maybe it was posted before, so excuse me.
Diesel engine originally was designed to run on oil. I've seen several run-away diesel that would burn own oil.
My thought is that if you have diesel with WVO system and heated tank, you can run used engine oil. Which will be much easier to use. In most cases it won't have water in it, and it was running thru filter already, so you need to filter it less. Plus it will have additives left over that might be beneficial.
Have anyone done this?
Edited by wwillson (01/15/12 08:16 PM)
Edit Reason: subject line spelling
#2494713 - 01/15/12 07:23 PM Re: Used engine oil instead of WVO? [Re: zyxelenator]
zyxelenator Offline
Loc: Louisville,KY
Just found some on different forum
"I have ran used motor oil, transmission fluid, hydraulic fluid, dielectric fluid,mineral oil and etc.. in my 1995 chevy diesel. A diesel motor will run fine on any lightweight oil. When running used motor oil it would be a good idea to either mix it with diesel or run it in a heated separate tank (Same as WVO) the reason why is th viscosity is thicker than diesel and is harder for your lift pump and IP to pump (Potentail wear) at 160f all oils flow the same as diesel. as far as filtering, make sure no water or big chunks of anything is in it and pour it in. Anything that passes thru your main fuel filter is small enough to pass thru the injectors and burn up in the cylinder, blow out tailpipe. It will NOT plug your injectors! After a year of running this stuff (Mostly used ATF) my injectors look clean as new. I cannot run used motor oil straight as in the later model chevy's they have a optic sensor that is for timing. Unfortunately they put this device in the fuel itself and it cannot read correctly in black oil. Ford and Dodge should be fine.(Or early GM's)Everytime you do a search on this subject people will tell you how bad this is on your motor.Plugged injectors, ATF is corrosive (Don't want it in my tranny then either) are some of the things said. Once you de-bunk all that then the issue of the enviroment comes up even though if you look up waste oil burners (Which burn at a lower temp than a diesel combustion chamber) they all tout their product as "enviromently friendly" and they are EPA approved! I could go on all day but I think i'll just go fill up with some more used ATF and be on my way"
99 Camry V6, 5 speed M/T
148k miles.Current fill:5w-30 G-oil,OVERSIZE P1, some Kreen and Ceratec added.
Lubro Moly 75w90 synthetic hypoid oil,with Moly
#2494715 - 01/15/12 07:24 PM Re: Used engine oil instead of WVO? [Re: zyxelenator]
zyxelenator Offline
Loc: Louisville,KY
That would be true BITOGERomobile smile running own(and friends) used oil smile
#2494738 - 01/15/12 07:35 PM Re: Used engine oil instead of WVO? [Re: zyxelenator]
eljefino Offline
Loc: ME
#2494754 - 01/15/12 07:45 PM Re: Used engine oil instead of WVO? [Re: zyxelenator]
JimPghPA Offline
Loc: Pittsburgh,PA U.S.A.
I once saw a small diesel generator on a traffic signal set up on a small trailer for signaling cars to change lanes when entering a construction zone. It has a black rubber prime button that primed the engine with its own oil for start-up.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
#2494777 - 01/15/12 08:01 PM Re: Used engine oil instead of WVO? [Re: zyxelenator]
Clevy Offline
Loc: Saskatoon canada
At 160f all oils flow the same? So I guess those numbers on the front of the bottles don't mean anything.
I am interested in this topic. Used oil for fuel in a diesel. Can this be done with a 97 6.5 chev turbo diesel? And as far as the tranny fluid. Do you just mix it in with the diesel.
If this is possible to do in a 97 chev turbo diesel with no ill effects I will be grabbing a 55 gallon drum to pour all the oil from oil changes and tranny fluid changes into. What's the mix ratio. How much oil can you get away with mixing into the diesel.
2006 Charger RT
Miles x 2 per oil filter
#2494789 - 01/15/12 08:09 PM Re: Used engine oil instead of WVO? [Re: zyxelenator]
zyxelenator Offline
Loc: Louisville,KY
It said somewhere up to 10% without any mods.
#2495692 - 01/16/12 05:17 PM Re: Used engine oil instead of WVO? [Re: zyxelenator]
Shannow Online   content
Loc: Oz
Depends on the engine and the Injector Pump.
My old landcruiser, the Bosch inline IP was to be filled with SAE30 on rebuild...it would really run on anything.
Most of the modern rotary pumps fail when the operating viscosity ends up much higher than diesel, as the thrusts become overloaded and underlubricated.
#2527474 - 02/06/12 05:46 PM Re: Used engine oil instead of WVO? [Re: zyxelenator]
Michael_P Offline
Loc: By the Lake
Anything with modern emissions systems, I don't know if I would try. Other than that, sure. JimPghPA brings up a point. The military still uses those generators with usually continental engines. They have breaker point regulators and rheostats for voltage controls. They brushes on the generator head can be changed in about 20 seconds. Long story short, I remember the oil primer. The problem is today today's oils have higher flash points.
#2534973 - 02/13/12 11:55 AM Re: Used engine oil instead of WVO? [Re: Michael_P]
HerrStig Offline
Loc: Boston, MA
I'd be real careful what I put in a high tech direct injection engine from Dieter and the boys.
#2615757 - 05/02/12 11:30 AM Re: Used engine oil instead of WVO? [Re: Michael_P]
sdowney717 Offline
Loc: Newport News, VA
EMP pulse destroys electronics. So mechanical electronics to military would be a good idea. Imagine all the high tech gear is no longer going to work if a successful EMP attack was delivered.
http://en.wikipedia.org/wiki/Electromagnetic_pulse
Quote:
n July 1962, a 1.44 megaton (6.0 PJ) United States nuclear test in space, 400 kilometres (250 mi) above the mid-Pacific Ocean, called the Starfish Prime test, demonstrated to nuclear scientists that the magnitude and effects of a high altitude nuclear explosion were much larger than had been previously calculated. Starfish Prime also made those effects known to the public by causing electrical damage in Hawaii, about 1,445 kilometres (898 mi) away from the detonation point, knocking out about 300 streetlights, setting off numerous burglar alarms and damaging a telephone company microwave link.[7]
Rebuilding would take years, meanwhile life would be over for many.
#2622265 - 05/09/12 02:07 PM Re: Used engine oil instead of WVO? [Re: zyxelenator]
BrianWC Offline
Loc: Louisiana
I posted on this topic when I first started accumulating a lot of waste oil in the aftermath of some auto-rx treatments. General concensus was quart at a time in something like an old Merc oilburner would be fine. Anything more in anything newer...skip it.
2002 Honda CR-V EX AWD
2014 Ford Mustang GT
2015 GMC Yukon XL SLT
#2658550 - 06/19/12 11:36 AM Re: Used engine oil instead of WVO? [Re: zyxelenator]
Kestas Offline
Loc: The Motor City
I believe someone once wrote that some trucks have a switch where they can feed their engine oil into the fuel line, to use it as fuel just before an oil change.
#2665257 - 06/26/12 05:39 AM Re: Used engine oil instead of WVO? [Re: zyxelenator]
Loc: Oz
Was IIRC the Cummins that regularly fed a quart or two of engine oil into the tank, and replenished from a tank
#2681619 - 07/12/12 10:37 AM Re: Used engine oil instead of WVO? [Re: sdowney717]
HerrStig Offline
Loc: Boston, MA
Hang on to your old Collins tube gear!
Page 1 of 2 1 2 >
