This makes 4 for Redline. Keep in mind that they are "heavy" for their grade, so their 5w30 is comparable to most 5w40 oils. I would go with the 0w40 if you want that weight as it has a far stronger ad pak than their 5w40 (which is really a diesel oil).
I have used their 5w30 and 0w40 to great success on the track in my 328. Better still, not only are their oils fantastic for track applications, they are also excellent on the street. Pair it with a good filter and you are good to go!
Might be worth looking into the Royal Purple XPS oils for track use. They are specifically designed for this purpose, contain a hearty ad pak (tons of zddp, over 1200ppm I believe), and are very popular with the "muscle car crowd" (and in some Euro car circles; I know that I have been extremely pleased with their "regular" oil in my cars). They also make, IMO, some of the best oil filters around, so check and see if they make one for your car, it is worth doing.
I am disappointed they do not have any available for my Bimmers, but you can bet that the moment they do, I will be stocking up!
Perhaps a magnetic drain plug would be a good idea for your car?
Sincerely,
nleksan
