Hi everyone,
I bought the van one year ago. The previous owner had all the
records and the van was always serviced at the dealer. ATF
was changed about every 30k(sump only). I was aware of the
poor history of the Odyssey transmission, and did a 4X fluid
change when I bought the van. Sent an oil sample to the NAPA
lab, and got a "severe" warning.
Thanks for your advice and comments!
Oil Valvoline Maxlife Dex/Merc
In Use 12,881
Unit 138,155
Metals
Iron 41ppm
Cr Lead 1
Cu 14
Tin Al 65
Ni Ag Ti V
Contaminants(ppm)
Si 24
Na 3
K H2O
Additives(ppm)
Mg 28
Ca 302
Ba P 635
Zn 68
Mo B 383
Physical Tests
Viscosity(cst 100C) 6.3
Solids
Acid 2.33
Lab comments: Torque converter/pump wear indicated. Silicon level satisfactory. Water content acceptable. Viscosity within specified range.
Action: Inspect for source of wear. Drain oil from unit and resample after corrective action taken.
In Use 12,881
Unit 138,155
Metals
Iron 41ppm
Cr Lead 1
Cu 14
Tin Al 65
Ni Ag Ti V
Contaminants(ppm)
Si 24
Na 3
K H2O
Additives(ppm)
Mg 28
Ca 302
Ba P 635
Zn 68
Mo B 383
Physical Tests
Solids
Acid 2.33
