Purolator has announced the launch of Purolator Synthetic, a new oil filter featuring 100 percent synthetic media that the company says is custom-engineered to allow motorists to realize maximum benefits from synthetic motor oils.
“The key benefit of synthetic oils is chemistry that allows them to perform for extended periods of time,” said Chuck Kerrigan, director of marketing, for Purolator. “In order to take advantage of the extended life offered by synthetic oils, motorists need an oil filter that can capture and hold the tiny particulates that can accumulate over time. Now, Purolator has introduced the Purolator Synthetic, an exciting new filter that incorporates fully synthetic media combined with a specially designed media support system and other component technological innovations for longevity that allows motorists to enjoy the full benefits of longer-life synthetic oils.”
Specifically, Purolator Synthetic utilizes 100 percent synthetic media with pleat support technology containing wire backing that is engineered for today’s high-tech engines, according to the company. The result is a filter that has substantially more capacity than conventional oil filters. This allows the filter to capture and safely hold more contaminants generated over the extended life of synthetic oils without getting clogged, Kerrigan said.
At the same time, Purolator Synthetic features 99 percent efficiency, which means that it can capture and safely hold 99 percent of particulates 25 microns in size or larger. A micron is a millionth of a meter.
“It is this extraordinary combination of capacity and efficiency, along with design technology, that maintains the integrity of the media for extended periods of time,” said Kerrigan. “This makes Purolator Synthetic a 10,000-mile filter available for those motorists that are using synthetic motor oils in their vehicles.”
