If you look up the filter for a 3.0L Duratec for Escape, Tribute vehicles, you come back with a version of a '2' filter - EG2, XG2 (Fram); MPH2 (C-T Motomaster); QS2 (Quaker State)...
Canadian Tire doesn't carry 'QS2' filter in the Quaker State selection. I was asking them about substituting a MM filter for a QS oil+filter deal they had, and the parts counter guy went to the back, and got a Quaker State QS173 filter.
Guy said that QS was using this new filter in these applications. The filter is much, much smaller - like half the size. The rubber gasket lined up just fine, and the inlet hole looked the same size....is this the equivalent of the new Motorcraft 'FL500' that can be used in these applications?
I chickened out, and went with a Motomaster MPH2 filter. I know that one works, b/c that's what I used last time, and I can't take any chances that a filter won't fit when doing an OC.
Was I silly?
Was I silly?
